Old 07-27-2011, 09:50 AM   #1
best size and type tile for a shower floor
for the shower floor, as regards to slipping , do you use porcelon,ceramic
travertine or?
what is the best size 4x4 6x6 etc? anything but the 1x1s
kt82 is offline   Reply With Quote
Old 07-27-2011, 10:26 AM   #2
Experienced
Jackofall1's Avatar
I personally like the 2 x 2 tumbled marble, looks great and it is not slippery, any glazed tile will be a slip hazard.
Regardless of the tile type always remember tile and grout are not water proof.
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
kt82 (07-28-2011)
Old 07-27-2011, 01:50 PM   #3
One of the guidelines for tile is slip resistance. Beyond the common sense of:
Matte tiles are less slippery then high gloss.
Textured tiles are less slippery then smooth tiles.
Tiles will have a slip resistant number associated with them. Sometimes it's on the box with the rest of the ratings.
Tile size can be an issue with sloped tile bases. You should stay under 4" so the tiles can be installed to drain the water properly. If you have a floor mount drain that spans one side of the pan, you can go larger as the tiles are all in one sloped plane.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
kt82 (07-28-2011)
Old 07-27-2011, 08:16 PM   #4
Tileguy
JazMan's Avatar
travertine or?
Porcelain would be the first choice. You should never use regular soft bodied ceramic on a shower floor. Natural stone, especially tumbled travertine can be a nightmare to maintain after a while. However people like the looks, when new at least. The best size is probably 2", although 3-4" is doable. Small glazed tiles are not slippery, just stay away from larger smooth tiles.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
The Following User Says Thank You to JazMan For This Useful Post:
kt82 (07-28-2011)
Old 07-28-2011, 10:17 AM   #5
I would suggest a small "rock-type" mosiac. Sold at any tile store or local wherehouse store, some in-stock, some special order. People like it because it's not slippery and they say it massages their feet! Feels good too! Seal it, as it is a natural stone though. And it does come in different colors.
ttr13r is offline   Reply With Quote
Old 07-28-2011, 10:33 AM   #6
Experienced
Jackofall1's Avatar
Jaz
Jazz, just wondering what is the maintenance nightmare that you refer to when using tumbled travertine? I have had tumbled marble down for (2) years (a short time in the scheme of things) with no issues to date.
Mark
Old 07-28-2011, 11:32 PM   #7
I don't think of marble as being porous. would tumbled marble be more porous?
when you seal the grout joints ,does that make the entire floor less porous
Old 07-28-2011, 11:37 PM   #8
Tileguy
JazMan's Avatar
Hi Mark,
Glad to hear you are happy with your tumbled travertine shower. Maybe you applied several or many coats of sealer and either dry it or it is able to dry out well. Maybe you take good care of it. I have found some people having trouble being that its fairly porous, has some holes and of course kinda rough with some texture.
Marble is very porous and generally a poor choice in wet areas.
I agree if installed correctly and sealed well and as needed, it can work well. Especially if it's installed with the Kerdi Membrane/Drain system which allows tiled shower to be waterproof and are able to dry quickly.
Jaz
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 10 01-25-2010 11:01 PM
What size and type of nails to use keviadams General Discussion 2 09-28-2009 01:25 PM
Tile backer boards types and size newgarage Tiling, ceramics, marble 3 01-07-2009 11:51 AM
What are the joist requirements for a tile floor? slatergrl Flooring 8 07-16-2008 11:08 AM
What type / size screws for subloor project... scheenstra Building & Construction 1 05-17-2008 09:22 PM
