Best Screws To Tighten Up A 3/4" Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2015, 12:46 AM   #1
Rewards Points: 32
Best screws to tighten up a 3/4" subfloor
I am about to put in a wood floor in a second floor room. I want to screw down the existing 3/4" subfloor to the joists. The floors squeak badly from poor workmanship. What are the best screws to use for this.
Thank you,
Ed T.
edspyhill09 is offline   Reply With Quote
Old 01-04-2015, 01:37 AM   #2
DIY staff
Rewards Points: 7,174
I use the gold ones---usually 2"--1 3/4" will be fine also--
drywall screws snap off--so do not use those--
edspyhill09 (01-04-2015)
Old 01-04-2015, 04:18 AM   #3
Rewards Points: 14,026
I use a lot of ceramic coated decking screws for this job, less cam out.
Best tool to use to drive them is an impact driver.
Old 01-04-2015, 04:18 AM   #4
If possible you should glue the subfloor to the joist to eliminate squeak. Screws are not enough to fix it permanently.
Usually it is not possible to pull up a subfloor to do it properly so adding more screws will help lessen the squeaks now that the wood has all dried and settled. There are application specific flooring screws that have two tracks of teeth at different depths available. They are not much better than standard wood construction or deck screws for this, they supposedly speed up installation time as they are self drilling but hold no better or worse than a standard deck screw.
I had access to one section of squeaky subfloor in my home where we could access it from unfinished basement below. I removed all the existing fasteners and was able to get a bead of glue in from below before going back to refasten. The bedrooms had no such access so we only added screws from the top while doing a carpet replacement and after about 6 years they are squeaking just as much as before. Humidity changes and temperature swings seems to be the long term problem. Mechanical fasteners just are not enough to combat this seasonal movement and eventually the squeaks return.
If you read the installation instructions for an engineered joist system (we have the so called silent floor I-beam style joists) it requires glue. So the builder of our house clearly skipped that step. I think these systems were still relatively new when our house was built in the early 90's and the builders probably thought they were some kind of magic that meant they just had to screw down the subfloor and it would work.
Subfloor on properly sized and structured joists that is glued with a good poly based adhesive will almost never squeak.
QueBall is offline   Reply With Quote
The Following User Says Thank You to QueBall For This Useful Post:
Old 01-04-2015, 03:31 PM   #5
Rewards Points: 32
Is there one brand of screw that is gold?
Thank you for the advice.
Ed T.
Old 01-04-2015, 03:34 PM   #6
Rewards Points: 32
<deleted text>
Queball.
This is a second floor room so I don't have access to the joists. Hopefully the screws and the hardwood floor running perpendicular to the joists will diminish the problem.
Thanks,
Ed T.
Old 01-08-2015, 04:33 AM   #7
DIY staff
Go to the Home Depot---they are just multipurpose screws--in the isle next to the drywall screws---they are plated gold color---no special brand--
Old 01-08-2015, 11:25 AM   #8
Rewards Points: 144
+1 They have phillips head or torx.I prefer the torx head and a bit comes with the screws.
After screwing the subfloor down check for flatness or you may still have problems with your new floor.
mako1 is offline   Reply With Quote
Old 01-09-2015, 08:12 PM   #9
Rewards Points: 32
In Home Depot the gold screws are SPAX.
Thank you,
Ed
Replace Rotted Subfloor Kory Beam Building & Construction 37 12-16-2014 05:17 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 07:34 PM
replacing subfloor for tile upgrade bucaronco Flooring 5 07-29-2009 04:35 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General DIY Discussions 8 05-11-2009 07:09 PM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 08:06 AM
