Best Practices To Fix Loft Flooring... - Flooring - DIY Chatroom Home Improvement Forum
Old 10-16-2011, 08:03 PM   #1
Best practices to fix loft flooring...
My wife and I bought a 8 year old log cabin last year that needed a lot of work. Currently we are trying to redo the floor for our loft. The flooring is 2 x 8 T&G yellow pine and was nailed and glued to the rafters (which are 4" x 8", 32" on center). The reason we are redoing the floor is because just about all the boards are cupped and there are up to 3/8" gaps between the boards (the tongue and groove separated).
At this point, we have taken down all the flooring and put it through a planer to get the boards flat again. Now I am trying to figure out what to do with the tongue and groove in order to get them matched up again. My thoughts are to increase the width of the groove and then use felt/tarpaper to wrap around the tongue so when I put the boards back together, I will get a snug fit with no creaking. Any thoughts would be greatly appreciated. Also, do I want to glue the floor down again (and nail/screw).
As for starting installing a new floor... this is not an option at this point - we already put waaay to much into this place!
Thanks in advance!
carolina_bound is offline   Reply With Quote
Old 10-16-2011, 08:28 PM   #2
DIY staff
Rewards Points: 7,174
Another option is to groove both sides and use a spline between the boards---
rusty baker (10-16-2011)
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 03:00 PM
Hardwood Flooring Pro's Best Practices Done That Flooring 3 08-22-2011 03:16 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-30-2011 12:06 AM
flooring choices for loft in garage into Flooring 0 02-28-2010 02:19 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
