Old 03-15-2012, 03:34 PM   #1
best place for marble flooring
What is a good place to buy marble tiles? Is online a good place to buy. I have found this site, is buying marble flooring ok to do it at an online store? http://www.travertinewarehouse.com/marble-tiles.html
neynme is offline   Reply With Quote
Old 03-15-2012, 04:16 PM   #2
Don't WANNA do it myself
mnp13's Avatar
I can't imagine that the shipping costs wouldn't negate any overall price savings. How much do you need?
Michelle
Fixing the re-muddling one room at a time...
mnp13 is offline   Reply With Quote
Old 03-15-2012, 04:55 PM   #3
sdsester's Avatar
Actually ground freight---not to be confused with UPS Ground or something---should not be that high. It may take some time to get to you though. Perhaps it is already factored into the prices you are seeing? If not make sure you know how they will ship and what the cost will be upfront.
Do the online places you are considering have minimums? That could be a deal breaker.
Have you seen a sample and does the supplier promise to match it with similar marble or are they just going to ship you a box of some sort of marble? Make sure what you expect to get is well specified as far as thickness, surface, color and so forth.
If you were taking business from an independent flooring supplier in your area I would cringe a bit but most are gone and all left are national chains or box stores. They give nothing back to the communities in which they exist anyhow so...
If the numbers work, go ahead and order online.
You should, regardless of where you get the marble, order some extra tiles for repairs you may need down the road. You may not find the same color again.
Especially with marble, be sure and get floor tiles that are thick enough to hold up.
sdsester is offline   Reply With Quote
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 12:01 PM
Is there a durable laminate flooring for kitchens? samalex Flooring 5 11-03-2010 03:55 PM
Flooring for hot tub room with tongue and groove base flooring. tkmiller Flooring 0 10-24-2010 01:21 PM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 08:06 PM
