Old 02-26-2009, 07:09 PM   #1
Best nail hole wood filler for hard wood floor
I am planning to refinish my red oak hard wood floor and use provincial color stain. (It is a medium dark brown color) I have drilled several holes in the floor and put in nails from the top to cut down on squeaks. Now I need to fill the nail holes with wood filler that will stain the same color as the provincial stain color. I plan to fill the holes, then sand the floor with a drum sander and stain it. The stain is oil based and the the polyurethane I will be using is also oil based. My question is "which wood filler should I use to get the nail holes to blend with the provincial color stain"?
Radjack is offline   Reply With Quote
Old 02-26-2009, 07:23 PM   #2
the Musigician
DangerMouse's Avatar
they make many different colors of filler but they are difficult to tell what color they'll be after drying and finishing. experiment first.
i have to wonder though at the effectiveness of nailing to stop squeaky flooring....?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 02-27-2009, 08:01 PM   #3
Nailing the hardwood floor was an ideal I got from the internet. I put in spiral nails at a slight angle and used a nail setter to sink them well below the surface before I sand it. It has been very effective reducing the noise when walking on the floor.
Old 02-27-2009, 08:38 PM   #4
the Musigician
ok, that's different then...
DM
Old 04-16-2009, 09:17 PM   #5
Wood Floor Guy
Since you plan to sand the floor, take a small handful of saw dust from the sanders gag, and mix it with carpenters glue. Use just enough glue to kame a thick, slightly damp putty. Use this to fill the holes, then hand sand. When you sand the floor, the match should be perfect!
Wood Floor Guy
Last edited by AtlanticWBConst.; 08-20-2009 at 03:53 PM. Reason: RULES VIOLATION: Advertising Link Removed From Signature
Wood Floor Guy is offline   Reply With Quote
Installing Laminate Flooring over Wood Laminate Floor bantammom Flooring 7 05-27-2011 04:34 PM
flooring frankiedog Flooring 7 12-05-2008 02:05 PM
Laying "new" wood floor next to sloping old floor troyce1 Flooring 25 10-16-2008 02:34 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 01:48 PM
Removing floor tile glue from a wood floor mrmordun Flooring 2 09-03-2008 10:41 PM
