-   -   Best nail hole wood filler for hard wood floor (http://www.diychatroom.com/f5/best-nail-hole-wood-filler-hard-wood-floor-39235/)
Radjack 02-26-2009 07:09 PM
I am planning to refinish my red oak hard wood floor and use provincial color stain. (It is a medium dark brown color) I have drilled several holes in the floor and put in nails from the top to cut down on squeaks. Now I need to fill the nail holes with wood filler that will stain the same color as the provincial stain color. I plan to fill the holes, then sand the floor with a drum sander and stain it. The stain is oil based and the the polyurethane I will be using is also oil based. My question is "which wood filler should I use to get the nail holes to blend with the provincial color stain"?
DangerMouse 02-26-2009 07:23 PM
they make many different colors of filler but they are difficult to tell what color they'll be after drying and finishing. experiment first.
i have to wonder though at the effectiveness of nailing to stop squeaky flooring....?
DM
Radjack 02-27-2009 08:01 PM
Nailing the hardwood floor was an ideal I got from the internet. I put in spiral nails at a slight angle and used a nail setter to sink them well below the surface before I sand it. It has been very effective reducing the noise when walking on the floor.
DangerMouse 02-27-2009 08:38 PM
ok, that's different then...
DM
Wood Floor Guy 04-16-2009 09:17 PM
Filler Tip
Since you plan to sand the floor, take a small handful of saw dust from the sanders gag, and mix it with carpenters glue. Use just enough glue to kame a thick, slightly damp putty. Use this to fill the holes, then hand sand. When you sand the floor, the match should be perfect!
Wood Floor Guy
