Best Masonite Subfloor Sealer? - Flooring - DIY Chatroom Home Improvement Forum
Old 10-25-2013, 02:14 PM   #1
Best Masonite subfloor sealer?
In our house I am removing all the carpets and installing "Cliks by Daltile", a floating ceramic tile floor that clicks together - no mortar, thinset or grout needed. One bedroom had plywood subfloor that I cleaned then sealed with 2 coats of Kilz Primer. Next bedroom has a masonite/hardwood floor with pet stains that need to be cleaned then sealed. I have read that it is hard for anything to stick to masonite and I need to use a laquer sanding sealer (2 coats) then Kilz will stick to it. Why would I need to use the primer? Won't the lacquer seal everything in the subfloor? Thanks for any help!
z00keeper is offline   Reply With Quote
Old 10-25-2013, 07:35 PM   #2
DIY staff
Rewards Points: 7,174
It will be easier and better to remove the old Masonite ---
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
joecaption (10-26-2013), Live_Oak (10-26-2013), z00keeper (10-26-2013)
Old 10-25-2013, 08:36 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
I agree with O'Mike. Masonite was supposed to be installed rough side up, but most people installed it smooth side up and nothing will stick to it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
Old 10-26-2013, 07:58 AM   #4
Rewards Points: 13,468
One over many build it faster and cheaper ideas that just did not work out.
Masonite siding, particle board, using 1/2 for subflooring, Quest plumbing, Cellotex sheathing all come to mind.
Old 10-26-2013, 09:18 AM   #5
K&B Designer
Live_Oak's Avatar
I'd also suggest you rethink this "floating ceramic tile" product. It's another "shortcut" similar to the masonite that you will probably regret. There are a LONG line of previous iterations of that that have done nothing but have claims and been discontinued. Tile requires a SOLID subfloor with no deflection, which is the very opposite conditions given by floating a floor. If you want a tile floor, you can certainly DIY a tile install. But, it won't be done with a shortcut method.
Live_Oak is offline   Reply With Quote
Old 10-26-2013, 10:37 AM   #6
Talking
Thank you all for the replies to my question - replacing the masonite is the way to do it right but I am keeping the "Cliks" tile. I have already used it in one room and love the way it turned out.
Tags
paint , sealers , subfloor , wood
Masonite Siding Sheets or Boards sore thumb Building & Construction 9 05-27-2013 09:09 AM
Beware Masonite doors Jeremy Hillary Boob, PhD Building & Construction 14 03-14-2013 10:01 PM
Masonite patio door DERVID_W Building & Construction 2 04-07-2011 06:41 AM
Hardie over Masonite siding??? canyonbc Remodeling 2 01-27-2010 08:57 AM
Can I tape joints on old masonite walls? ETD66SS Building & Construction 9 11-13-2009 05:09 AM
