Old 09-17-2009, 04:24 PM   #1
Default Best Hardwood Floor Covering
Wife and I just had our wood floors refinished (red oak strip with custom color). The final coat will be applied today. We would like to start painting on Monday. We will wear booties but is there a another protective product, i.e. paper, plastic, etc. that we should place over the wood floors to protect against foot traffic for a few weeks? We have a contractor coming to put up trim on Wednesday of next week and want to make sure we do the best we can to protect the finish on the floors.
jimmybush is offline   Reply With Quote
Old 09-18-2009, 12:23 AM   #2
whatever you use cover it 100%. The poly will be dry but it cures over time. If you have one area covered and another exposed to uv light the covered area will show darker.
I would cover the whole area with rosin paper. tape the seems. If there is dust or grit on the paper take it up and make sure none got underneath to damage the floors you are trying to protect.
What have I done is offline   Reply With Quote
Old 09-18-2009, 09:53 AM   #3
thanks for the suggestion. We would be applying the paper one day after the last coat of poly. Does that cause issues for example would the paper blead to the floor (red paper) and tint the floor.
Old 09-18-2009, 09:21 PM   #4
Drywall contractor
Rosin paper would be my suggestion also. I would ask the person who's finishing the floor to be sure you can use the paper that soon after the last application. Is there a reason why you didn't paint and THEN have the floors done??
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-19-2009, 08:22 AM   #5
Just my thought for sure but a 1 day dry time scares me. We always wait at least a week before we allow traffic of even limited amount on a poly coat.
I'd call the floor finisher an abide by his wish's. Better safe than sorry.
And as mentioned, cover the entire floor when you do put down the rosin paper.
Shamus
Shamus is offline   Reply With Quote
Old 09-19-2009, 03:31 PM   #6
i would be ok with the 1 day as long as the floor was dry to walk on. However I would tape all the seems and roll it up and let the floor "breath" when there wont be any traffic.
make sure paper is clean and free of grit and re-install the next day when work will continue
Old 09-20-2009, 04:49 PM   #7
Licensed Contractor
I recently had to do some work in a client's house in which the hardwoods had recently been refinished. To protect the floors, I first rolled out the a layer of foam padding used under some laminate/engineered floors. On top of that I laid 1/4' luan plywood, seams taped. At the end of the project, the floors were as prestine as when they were first refinished.
BTW, next time, finish the floors last.
Renovator,LLC is offline   Reply With Quote
Old 09-20-2009, 05:45 PM   #8
Drywall contractor
I have used 1/4" over new/existing floors where there will be heavy traffic (renovation mainly) for several days/weeks. I don't think painting would justify buying several sheets as opposed to a $9.00 roll of paper. There are some "hardboard" products that are less expensive that luan too. Of course if you put the "good side" down, you can us it for another project....
Old 09-20-2009, 07:25 PM   #9
Licensed Contractor
I figured luan would last a lot longer than rosin paper, given he wanted to leave it down for a few weeks.
Old 09-20-2009, 08:45 PM   #10
Drywall contractor
LLC, you're probably correct with your advice. I missed the part about the trim guy coming in. There's a 1/4" "hard board" product that's probably cheaper than the luan (actually "slick" on one side). I'll think of the name about the time I post this. That would be the safest bet. If nothing else, use 2 layers of rosin paper (tape the joints) and run one layer across the other.......
More On This Topic
Hard wood floors are also stained pretty easily. The first thing you can do is use a number two steel wool; this is the softest steel wool that you can find. And you’re going to dip that in a paint thinner and rub it over the stain a little bit... Read More »
Wood floorings are beautiful alternatives to carpet and tile in the home. They are easy to clean and look nice. However, it is important to maintain wood floors properly. Read on to learn more. Read More »
Many people are choosing wood flooring for their homes. This type of flooring is durable, easy to take care of and pleasing to the eye. There a two basic kinds of wood flooring: hardwood and laminate. Choosing the right wood flooring will add value to a... Read More »
Cork, a renewable resource, comes from the bark of the Mediterranean cork oak tree. Every 9 to 10 years, cutters carefully harvest cork bark without harming the host trees. Through a process of grinding and baking, craftsmen create cork flooring sheets... Read More »
What some people like to, say they've had this chest here for a long time and it was a real, kind of a dark red color, they may have something refinished just so they could change it to a lighter brown like this is now. And, that's some of the reasons... Read More »
Installing 3/4" Engineered Hardwood over Particle board New_Floors Flooring 3 07-13-2009 02:02 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 01:56 PM
old hardwood floor nailed from top; can it be refinished again? benshouse Flooring 0 01-15-2009 09:47 AM
How to tell what hardwood... evane Flooring 9 09-06-2007 03:42 PM
Hardwood Flooring is one of the Most Important Design Elements in your Home Decor doctorhouse Flooring 1 12-22-2005 10:17 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
