Best Flooring Option For Basement Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 07:53 PM   #1
Best flooring option for basement flooring
I have about 550sq ft of basement flooring to re-do; It was originally done in a slate tile but I had to rip up a decent portion of it due to the pipes shifting - so had to replace a decent amount of it. Now I need to re-finish the floor. The issue is its up to 1.5" uneven from the walls to the middle of the room (about 7').
I'm looking for options as to what to install, I don't want carpet - I've been looking at laminate flooring, potentially using dri-core for the subfloor - Can I use this without SLC or I have to level it pior? I've read a few other products on the forum and pretty open to suggestions.
bristo_99 is offline   Reply With Quote
Old 05-25-2011, 03:16 PM   #2
DIY Damo
Have you checked out the epoxy resin floors. Very nice and no maintenance.
diydamo77 is offline   Reply With Quote
Old 11-09-2011, 09:59 PM   #3
I prefer you have it stamped concrete way for you flooring so that it would not take a lot of time to manage and maintain it's appearance.
Kaylee is offline   Reply With Quote
Tags
basement floor , uneven floor
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
Another option for installing engineered wood flooring dutch Flooring 1 08-22-2010 01:28 AM
Trying to decide which flooring option to go with DIY newbie Flooring 2 02-14-2010 12:38 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
