Old 12-05-2010, 09:48 PM   #1
best flooring if foundation moves
I live in an area where the soil is clay and most homes experience significant movement. Most of the home is on an engineered slab, with a 1970s addition on a simple slab. This part of the house moves more than the rest. The carpet in the hallway and family room needs to be replaced. We would prefer wood/laminate or bamboo flooring. Which is the best given the foundation movement ? Durability and adding value to the home is also important.
needhelpinTexas is offline   Reply With Quote
Old 12-06-2010, 06:33 AM   #2
KCB
Well in a perfect world you would fix the movement problem.That being said use a engineered or laminate floating floor .
KCB is offline   Reply With Quote
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Round House Foundation Feasibility Mswick Building & Construction 23 02-27-2010 09:34 AM
Foundation Repair Help rasilun Remodeling 1 10-15-2009 11:26 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
wood flooring over slab foundation la15ota Flooring 3 03-25-2006 03:49 PM
