Old 10-08-2012, 04:28 PM   #1
Best floor to go over plywood (on slab)
Trying to make the most of what I need to work with- Original kitchen floor is 1/2 plywood nailed to concrete slab (With 2 layers of sheet linolium on top....)- Taking the 2 layers of linolium off since they are in bad shape- I don't want to pull up the plywood if I can help it (Yes I know it's not the best setup- But it's been that way for 40 years..... We don't want ceramic but want the look of ceramic....
What is my best option?:
1. Clean up plywood subfloor best I can and install Laminate tile like Armstrong Alterna?
2. Remove all old plywood (nailed down!)- and replace with new plywood- then install same as #1?
3. Remove plywood an put some other type of subfloor.
I think part of the reason the 1/2" was put is to make it look more uniform with the rest of the first floor which is all hardwood flooring...so I think something needs to go back atop the slab--
Since we don't want ceramic directly on concrete- that's what gave me the idea of the laminate tiles going on top of the wood
skinut2234 is offline   Reply With Quote
Old 10-10-2012, 12:20 PM   #2
bump!
Old 10-10-2012, 11:31 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Pull the plywood and install on the concrete. Wood on concrete is a bad idea.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 10-11-2012, 04:37 PM   #4
thanks- If I install laminate tiles- can I install backerboard over the concrete to keep tht floor level same as it is now? I'm worried if I take plywood up- the floor will be a lot lower than rest of the first floor
Old 10-11-2012, 08:07 PM   #5
No, tile board should not be installed over a slab, sure way to have mold grow under it.
Just use a transition strip.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
rusty baker (10-11-2012), ToolSeeker (10-13-2012)
Want to Install Ceramic/Porcelain and Insulate Basement Slab illusion8055 Building & Construction 2 08-15-2012 02:19 PM
Repairing concrete slab in shower JohnRoss Building & Construction 0 08-08-2011 02:20 PM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
Series of holes in periphery of basement slab BalowskiJ Building & Construction 4 04-18-2011 02:49 PM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
