-   -   Best embossing leveler? (http://www.diychatroom.com/f5/best-embossing-leveler-164223/)
Studly 11-20-2012 07:08 PM
We're getting ready to install MetroFlor Solidity 30 vinyl/ceramic (a.k.a. luxury vinyl) tile over our kitchen's sheet-vinyl floor, which is only about 15 years old and is in good shape (glued down very well).
We are going to put an embossing leveler down on the old sheet vinyl before tiling. Although we've tiled before, haven't used an embossing leveler before.
We found Planipatch (and the additive that you're supposed to use with it) at our local Menard's, but you're supposed to put it on in two different coats, at different strengths,which sounds like a lot of work, and I've read that it is a pain to sand once you put it down (although a Planipatch rep at their 800 number said that you don't need to sand it, that a putty knife will take care of high spots).
Anyone have recommendations on the best, easiest to use embossing leveler?
jrgodwindesigns 11-20-2012 07:20 PM
I've never heard of anything like this before I'd like to know more. Why go through all that trouble for vinyl flooring? Is there an issue with putting tile?
Studly 11-21-2012 01:34 PM
The embossing leveler is used to smooth out the embossed pattern in the sheet vinyl, so the tiles have something smooth and level to stick to.
Since posting my original message, I've since read that a lot of people prefer Ardex/Henry's embossing leveler ... anyone know if this is a big step up from Planipatch mixed with Planipatch Plus, or if it's cheaper or easier to use?
poppameth 11-22-2012 07:32 AM
Many companies make a light weigh patch now like Ardex Feather Finish. With the Ardex, you prime the vinyl and then mix up the patch and lightly skim the floor with it sanding down any rough spots afterward. We've used a lot of Plani Patch. If you mix it the way they tell you to it will be far too thick for the way you intend to use it. And yes when mixed with the additive it does not sand well at all. The Ardex does not have an additive since it goes over a bonding primer and sands much easier.
poppameth 11-29-2012 06:51 AM
An embossing leveler is just designed to flatten out the surface. If the vinyl is deeply patterened, that pattern may show through the new flooring if you don't fill it with something before installation. It can also give the new adhesive a better surface to bond to.
