Best Carpet Tiles For Basement? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-10-2012, 07:06 PM   #1
Rewards Points: 184
Best carpet tiles for basement?
What are the best carpet tiles for a basement?
I get water in every 5 years or so, so something not ultra-expensive, or perhaps something that I can extract the water from easily.
The other problem is the baseboards are 3/4" off the surface, so preferably a carpet tile about that thick so that there isn't a gap. (I'd rather not take out baseboards and reinstall them if possible.
Do you have any suggestions of what I should go with?
TIA
abefroman is offline   Reply With Quote
Old 01-11-2012, 12:31 AM   #2
carpet
i don't have any idea about the carpet tiles, but i will ask my friend about the best carpet tiles.
Temporary wallshttp://www.allweekwalls.com
Temporary Walls is offline   Reply With Quote
Old 01-11-2012, 03:14 PM   #3
Below Grader
TIA
Hi Tia,
I would suggest you look into carpet tiles that are specifically developed for basements.
These are 100% waterproof, floating, interlocking tiles that are raised from the slab by pegs, creating a space between the concrete and the carpet that allows air to circulate and dry the slab when it is wet.
If your basement ever floods, you can take them off, dry them out and put them back.
CyFree is offline   Reply With Quote
Old 01-12-2012, 09:49 PM   #4
info
I need more information.Please inform me
The Following 2 Users Say Thank You to Temporary Walls For This Useful Post:
abefroman (01-12-2012), mae-ling (01-12-2012)
Old 01-13-2012, 09:24 AM   #5
Below Grader
Here's a video about basement flooring options, which includes information about the carpet tiles I am talking about
Old 01-13-2012, 09:49 AM   #6
Rewards Points: 133
You could check out http://www.bigfloors.com/Snap-Carpet-P17C3.aspx
I have used the GarageDeck product in my laundry area, and it worked great. The link shows the carpeted ones they have. the nice thing is that they all interlock together, so you could do carpet in some areas, wood, or tiie in others. Big Floors usually has the cheapest that I had found for the garage deck. Didn't look at the others. You could always get the GarageDeck and then an outdoor carpet to go over it.
jimmyfloyd is offline   Reply With Quote
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Asbestos tiles under carpet Sam53 Flooring 2 01-22-2011 09:37 PM
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 07:29 AM
rumpus room - best flooring- carpet tiles/ laminate fiona Flooring 2 10-05-2008 08:47 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
