Old 07-15-2011, 08:20 PM   #1
PTO
Below Grade vapour barrier on concrete below engineered hardwood....
what does everyone recommend as the best product???
Thanks in advance
Mark : )
PTO is offline   Reply With Quote
Old 07-17-2011, 05:32 PM   #2
I'm going to get 6 mil poly sheeting and tape the seems with moisture resistant tape. I've even been toying with using real hardwood in the basement, but I know that's a bad idea. What will you be using, foam underlayment?
mikegp is offline   Reply With Quote
Old 07-17-2011, 11:23 PM   #3
PTO
The flooring store where I bought it recommended a "closed cell" 3 mil product branded "whisper walk". I researched out and it seems that something thicker would be better. There is a product called TuTuff but it seems as though the only flooring application is in crawl spaces. It seems almost too good to be true when you read the website.
I would probably steer away from hardwood as I hear any moisture can cause the ends to curl. This is especially true for the wider planks from what I hear.
Its funny bc they do not recommend normal hardwood below grade but you can use a non engineered bamboo below grade. I think its because the bamboo is essentially manufactured from the grass through a special process. Looking for a good product that works especially well. Hopefully I can find something soon..........
let me know thoughts.........
Thanks for the reply
Mark
Below Grade Bathroom Addition (Concrete / Flooring Question) cmremmert Building & Construction 1 07-12-2011 07:16 AM
Which type of glue to buy for engineered hardwood floor on concrete sub-floor in FL? noone Flooring 2 06-08-2011 09:27 AM
Insulating above grade concrete wall jhedger69 Building & Construction 6 07-23-2010 09:06 AM
Roxul without vapour barrier? giannit Building & Construction 8 01-26-2010 05:39 PM
Best underlayment for Engineered hardwood on concrete jcieutat Flooring 0 11-28-2009 05:14 PM
