-   -   Below Grade vapour barrier on concrete below engineered hardwood.... (http://www.diychatroom.com/f5/below-grade-vapour-barrier-concrete-below-engineered-hardwood-110866/)
PTO 07-15-2011 07:20 PM
what does everyone recommend as the best product???
Thanks in advance
Mark : ):thumbsup:
mikegp 07-17-2011 04:32 PM
I'm going to get 6 mil poly sheeting and tape the seems with moisture resistant tape. I've even been toying with using real hardwood in the basement, but I know that's a bad idea. What will you be using, foam underlayment?
PTO 07-17-2011 10:23 PM
Have not fully decided..........
The flooring store where I bought it recommended a "closed cell" 3 mil product branded "whisper walk". I researched out and it seems that something thicker would be better. There is a product called TuTuff but it seems as though the only flooring application is in crawl spaces. It seems almost too good to be true when you read the website.
I would probably steer away from hardwood as I hear any moisture can cause the ends to curl. This is especially true for the wider planks from what I hear.
Its funny bc they do not recommend normal hardwood below grade but you can use a non engineered bamboo below grade. I think its because the bamboo is essentially manufactured from the grass through a special process. Looking for a good product that works especially well. Hopefully I can find something soon..........
let me know thoughts.........
Thanks for the reply
Mark :thumbsup:
