Below Grade Basement Tile: Insulation? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-08-2015, 11:52 AM   #1
Rewards Points: 76
Below grade basement tile: insulation?
So I was considering an electric radiant floor setup for our basement (in mass).
But I think cost is a bit high for a room only used on weekends...
We've had temperatures consistently below 20*F the past few days, and honestly the slab isn't all that cold (a cheap point and shoot thermometer is reading 56* on the bare slab, with the rest of the house at about 62). It's chilly, but not unbearable if you're wearing socks.
I want to preserve some ceiling height, so I'd like to keep my flooring and substrate below 1".
I was originally considering ditra or super seal direct to the slab, and then ceramic tile.
But now I'm wondering if maybe using 1/2" xps and cement board would be a good Idea, instead of ditra?
Delta FL or DMX one step would be great, but vinyl flooring doesn't have the same appeal as ceramic.
gizzygone is offline   Reply With Quote
Old 01-08-2015, 07:25 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 2,464
What not do it right and just put the ceramic directly on the slab with thinset?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-08-2015, 07:45 PM   #3
Rewards Points: 76
Is that truly the right way?
I know the appeal of the ditra is the "uncoupling" to prevent cracking with any slab movement. Also, I liked the fact that it acts as a vapor barrier to help keep moisture down.
The foam, I figured, provided an R-value while still giving you an "uncoupling" from the slab.
Old 01-08-2015, 08:43 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 2,384
Which tile installation method allows xps and concrete backer on a slab?
Go with Ditra for the reasons you stated, or direct if the floor is in good shape and small.
Jaz
Tile 4 You LLC Troy, MI
DITRA Installs - KERDI Watertight-Mold-Free Showers. I have NEVER made a mistake, I thought I did ONCE, but, I was WRONG! A+ BBB rating - est. 1987 - over 50 yrs. exp.
Old 01-08-2015, 09:27 PM   #5
Rewards Points: 76
Jaz
It was my own thoughts. Wasn't sure if it would work to add a touch of r value to keep the floors a bit warmer.
Old 01-08-2015, 10:06 PM   #6
Tileguy
JazMan's Avatar
OK, now you know what to do. Want a warmer floor? Spend the $$$ for the electric in-floor-heat with timer thermostat, or slippers.
The rest of the house is 62 f. ? Yikes you like it cold huh?
Jaz
Old 01-08-2015, 10:34 PM   #7
Rewards Points: 76
Jaz
Well, I started another thread about the electric heat, only to find out installing the element directly to the slab would result in me heating more slab than tile...
Haha, 62 is the daytime temp for the dogs. We pump it up to a toasty 68 when we're home... I was just stopping back in for lunch when I did my temps
Old 01-08-2015, 10:52 PM   #8
Rewards Points: 1,922
Tile in basement looks cold feels cold. Carpet in basement looks warm feels warm.
SeniorSitizen is offline   Reply With Quote
Old 01-08-2015, 11:14 PM   #9
Tileguy
JazMan's Avatar
Yes, and it's not sanitary for a bathroom.
It's also not a good idea for basements that are humid or tend to have seepage now and then. But it's definitely warmer.
Jaz
Insulation in basement ceiling for soundproofing -- will basement be too cold? jmai14 HVAC 3 11-16-2013 11:04 AM
Basement wall insulation / remodel question Chokingdogs Insulation 2 03-14-2013 01:26 AM
Insulate rim joist & basement walls- if exterior walls have no insulation? cbrc5eric Insulation 5 02-01-2012 08:47 AM
Insulation in basement floor joists and integrated garage speedster1 Building & Construction 3 12-07-2010 06:44 PM
basement issues - tile, mastic, moisture pfisch Flooring 6 12-01-2008 02:35 PM
