Bellawood - Flooring - DIY Chatroom Home Improvement Forum
Old 01-10-2011, 04:20 PM   #1
Rewards Points: 49
Bellawood
I installed brazillizn cherry 3/8 x 3" hardwood flooring. Some of the flooring is bowed and I would like to replace them. I was told you can drill a hole at each end, cut it out and replace it with a new piece. Can anyone explain this in more detail?
worker903 is offline   Reply With Quote
Old 01-10-2011, 04:22 PM   #2
Rewards Points: 200
measure the width of the board to be taken out and the one to be put back in to make sure the replacement is the same size .
make two angle cuts near the end joints about 1" away from the side joints.
make two length cuts 1" from the side joints . you should be able to pop out the center of the board now.
carefully chisel up to the end joints . take a pry bar and tap the remaining board from the side joints.
On the replacement board cut the bottom of the grooves off and cut a 45 on the bottom of the groove that is left.
Put a bead of PL400 in the hole slide the board into the hole and apply a weight .
I always do a dry run first . Place a 1' piece of strong string like fishing line across the hole . if the board don't fit flush it will need to be trimmed a little more.
This way you will be able to get it back out.
Floor Doc is offline   Reply With Quote
The Following User Says Thank You to Floor Doc For This Useful Post:
worker903 (01-10-2011)
Old 01-10-2011, 05:52 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Bellawood makes good kindling.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 01-10-2011, 07:40 PM   #4
Rewards Points: 49
Thank you Floor doc for your professional answer. Was very helpful and I appreciate it much.
Old 01-11-2011, 05:06 AM   #5
Rewards Points: 200
Welcome . Good Luck .
Just be careful , and take your time. We only want to replace one board .
Advice needed on installation of BELLAWOOD 5/16" x 2-1/4" Select Brazilian Walnut lifterpuller Flooring 2 05-30-2010 02:30 AM
replacing carpet with bellawood in multilevel condo diankay Flooring 9 02-03-2010 06:22 PM
