Old 12-06-2012, 01:42 PM   #1
bedroom wood floor
I use oil base minwax stain, I did this almost 3 days ago, but it not competely dry, it is sticky to the touch. what should I do.?
babymorena is offline   Reply With Quote
Old 12-06-2012, 01:45 PM   #2
bedroom wood floor
If I need to add a poly.finish which one would be best on a oil base stain. I'm not too familiar with top coats. please help. running out of time. thanks.
Old 12-06-2012, 03:10 PM   #3
bedroom wood floor
Did you wipe up the excess stain after about 10 minutes or did you leave it on to soak in. What kind of floor is it hardwood or bamboo? If hardwood what species? And they make a regular finsh for wood floors.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Vent/Duct from addition ceiling to bedroom floor? awbstuff HVAC 1 08-06-2011 11:35 AM
Wood floor drying, build raised platform? Puzzles Flooring 3 05-03-2011 04:23 PM
Best nail hole wood filler for hard wood floor Radjack Flooring 4 04-16-2009 09:17 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 11:56 PM
