Bedroom Over Garage, New Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 01:37 PM   #1
Rewards Points: 1,046
bedroom over garage, new laminate flooring
Hello,
I will install laminate flooring (12mm from Lumber Liquidators) on the whole 2nd floor of my house
My daughter's bedroom is over the garage, and I noticed it was colder than the other rooms
I was thinking to put a first layer of radiant barrier (http://www.lowes.com/pd_219377-56291...cagpspn=pla%22) over the plywood, and on top of it this (http://www.homasote.com/products/440-Soundbarrier.aspx) available at Home Depot. That sound barrier is very rigid and won't interfere with the attached padding of the laminate
What do you think?
french_guy is offline   Reply With Quote
Old 02-03-2013, 03:11 PM   #2
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
Are you looking for advise on the design or how to make it a warmer room?
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
Old 02-03-2013, 03:29 PM   #3
I would say say both....
1) Is it technically "viable"?
2) Will the Reflectix material help to get a warmer room...?
Should it be:
*) Plywood / Reflectix / Homasote / Laminate
or
*) Plywood / Homasote /Reflectix / Laminate
Old 02-03-2013, 03:32 PM   #4
Rewards Points: 13,296
Cork underlatmant would also work.
The better way would be to air seal and insulate the room below.
Old 02-03-2013, 03:49 PM   #5
insulating the garage will be the next step....i guess
I can't do everything in the same time (time and $$$...!!)
Old 02-03-2013, 04:00 PM   #6
Rewards Points: 150
Insulating only slows the process down. It won't stop the room from gettiong cold if you're not putting enough heat in to keep up with the loss. What type of heating source do you have in that room?
Old 02-03-2013, 04:06 PM   #7
Wood Flooring & Carpentry
lawndart's Avatar
Since you've purchased the 12mm laminate flooring from LL, why not look into the eco silent, and Bella Premium underlayments they offer. Both of them act as sound, and moisture barriers, plus offer an R value to warm the floors.
lawndart is offline   Reply With Quote
Old 02-03-2013, 05:05 PM   #8
Rewards Points: 3,418
If you have not purchased the laminate,look at wood engineered flooring before you do anything else.
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
joecaption (02-03-2013)
Old 02-03-2013, 05:21 PM   #9
You do know that any hard flooring will still feel cold on bare feet, right?
Old 02-03-2013, 06:40 PM   #10
Too late, I placed my order this morning....1,000 sq ft !!!
Old 02-03-2013, 06:43 PM   #11
Yes, but if the room underneath is cold (garage), the radiant barrier should help, right? At least, it will not hurt........!!!
Laminate flooring in mobile home nanacac Flooring 2 11-02-2011 07:32 AM
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 02:20 PM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
