Bathroom Wall Tile Demolition. - Flooring - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 10:35 PM   #1
zep
Bathroom wall tile demolition.
I plan on replacing the tub in a 1952 home and convert to a shower. The walls for the tile are mortar and mesh in the tub area and half way up the surrounding walls. I am seeking tips on removing the tile, mortar and mesh. Should I just demo the plaster wall to the ceiling above the tile area to make it easier to remove the tiled area??
zep is offline   Reply With Quote
Old 02-24-2010, 09:48 AM   #2
Handyman
Rewards Points: 512
Sledge Hammer!
Quickest way is to use a 5lb sledge between the studs. Hitting the studs can cause damage to walls on the opposite side. Use a hammer and cold chisel around the plumbing though, as the weight of the plaster dropping can sever the pipes. To get a clean finish around the ceiling and adjacent walls, I usually use a small (5-6") metal blade on the sawzall to cut the mesh at the joints. Just be careful to angle the saw so that the blade does not go too deep as to cut into unknown wiring or plumbing.
Oh yeah, wear a mask and cover the vents and door spaces...its gonna be dusty as hell.
canadaclub is offline   Reply With Quote
Removing Bathroom Ceramic Tile Laid in 1970 mark2741 Flooring 6 12-08-2011 08:55 AM
grout vs caulk spin-off... another tile wall question diy'er on LI Tiling, ceramics, marble 3 11-02-2009 04:46 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 09:18 AM
Bathroom wall tile Ricksweares Flooring 10 02-26-2008 03:16 PM
