Bathroom-Vinyl-Linoleum - Flooring - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 04:12 PM   #1
Rewards Points: 97
Heh fellas
Were putting a new floor in the ensuite bathroom,the old vinyl sheet flooring wasn't even gluded down so it will come up real easy with no residue.Now we had a look at the Allure vinyl stick down floor tiles,seems easy enough that a DIY could put it down.Am I rightAnyone have any experience with this product.I know the green thing to do would be Linoleum.Is it high maintance? Do you know if it comes in stick down square tiles klike the vinyl.
P.S. Tile is out say's the boss!
Many Thanks
scarrylarry
scarrylarry is offline   Reply With Quote
Old 04-05-2012, 07:34 PM   #2
if you click the search up in the black bar and type in allure you will find numerous posts about allure flooring.
Old 04-05-2012, 07:41 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 126
Lino is not really DIY, like vinyl.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-05-2012, 10:02 PM   #4
linoleum is supposed to last for decades with low maintenance. Since its a natural product you wouldn't use harsh chemicals on it. It comes in squares like real tile or vinyl. It can be pricey. Someone else can tell you about install if thats the choice you're going with.
Curious though, is there a reason you may choose it over ceramic besides the fact that its softer and warmer on the feet. Just wondering
creeper is offline   Reply With Quote
Old 04-06-2012, 06:16 PM   #5
Rewards Points: 97
Hi guys
Thanks to all of you that have replied to my post, I appreciate the information!
Creeper,Well I thought my wife and I were going to do tile natural or ceramic,but she changed her mind saying it would be to cold.I mentioned that you can install it over in floor heating but she thiks it would be too expensive.I have not researched infloor heating I only know that it's an option.
scarrylarry
Old 04-06-2012, 09:06 PM   #6
Rewards Points: 99
is there a bunch of cuts and angles? I am putting fiberglass infused padded vinyl in the basement bathroom I am building right now. Maybe you could use the old stuff as a template? I bought Mannington Sobella stuff. http://www.mannington.com/Residential/Sobella.aspx
dwcopple is offline   Reply With Quote
Old 04-07-2012, 11:29 AM   #7
rkg
matching level to existing vinyl floor so new layer of vinyl floor can be laid down
deleted
rkg is offline   Reply With Quote
Old 04-08-2012, 01:00 PM   #8
Rewards Points: 97
dwcopple
Thanks for the reply and the link I will check it out.
To answer your question, no there are not any angles basic rectangular room, and I thought the same thing about using the present vinyl as a template as the present flooring is not glued down.
scarrylarry
framing for vinyl wind barrier (See photos) Carolyn252 Building & Construction 2 09-02-2011 04:50 PM
New porcelain tile to replace vinyl floor in kitchen PatrickGSR94 Flooring 5 03-03-2011 01:42 PM
Placing vinyl tile over linoleum phil74501 Flooring 5 11-11-2010 10:06 PM
self stick vinyl tiles over existing linoleum? cswanson69 Flooring 1 10-26-2010 12:16 PM
lifting vinyl in bathroom cinnabon Flooring 9 03-31-2008 09:10 PM
