Bathroom Vinyl Flooring Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 12-08-2008, 10:44 PM   #1
Rick
Bathroom vinyl flooring installation
My bathroom had vinyl flooring that is 30yrs old and I am replacing it but had some mice problems and had to replace subfloor and underlayment. The underlayment was particle board that had a white coating on it and the floor stayed put really good so I put 1/2" particle bnoard down again. but went ot the local Menards and they said that I should put a 1/4" underlayment over the particle board and I really dont want to do this so can I put the patching compound on it to fill screw hooles and joints and then use some sort of primer before installing the flooring. Thanks Rick
lemoncoke is offline   Reply With Quote
Old 12-09-2008, 12:43 AM   #2
maybe i suggested to you may ask for the person who expert to this Bathroom vinyl flooring installation,
_________________
Aprilaire Humidifier
jams003 is offline   Reply With Quote
Old 12-09-2008, 09:12 AM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Particleboard is a very poor product for any floor covering underlayment. In fact, if you would read the instructions from the makers of the flooring products I think you would find that particleboard is specifically excluded from use.
Old 12-09-2008, 11:01 AM   #4
Floorwizard's Avatar
you can try it, but failure is more likely with it.
Particle board tends to soak up water in the adhesive before it gets a chance to cure-
Floorwizard is offline   Reply With Quote
bathroom flooring carebear560 Flooring 9 07-24-2012 07:12 PM
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 9 02-08-2012 01:47 PM
Sheet Vinyl Flooring Removal yoods Flooring 2 11-22-2007 12:04 PM
