Bathroom Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 09-23-2012, 09:03 PM   #1
Bathroom Tile
I'm re-doing my upstairs bathroom. The toilet was mounted to the main floor with a wood sub-floor cut around it and laminant on top. I removed sub-floor and toilet. I will be replacing with concrete board and porcelin tile. Question is, how do I lay the concrete board (attach it to floor) and what is used to cut the board?
Savinmoney is offline   Reply With Quote
Old 09-23-2012, 09:37 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 412
Hi Savin,
Hopefully you didn't mean to say you're removing the subfloor and replacing it with concrete board. Please tell us what is on the joists and how many layers.
Once the base is determined to meet minimum specs you will install the tile backer into fresh thinset mortar, fasten and then tape all seams with the special mesh tape. What brand and thickness of board are you using? Cut with a utility knife, or carbide tipped laminate scoring tool made for the purpose. http://www.contractorsdirect.com/Carbide-Scoring-Cutter
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Savinmoney (09-24-2012)
Old 09-24-2012, 03:27 AM   #3
Jaz, I have 3/4 (I believe, it's pretty thick) plywood on the joists. There WAS a real thin wood on top of that with laminat. (That's what I called the sub-floor..may have used the wrong word!) I pulled it up. So, was going with concrete board on top of the plywood with tile on top of it. If this is ok to use, what thickness should the concrete board be? Thanks.
Old 09-24-2012, 09:59 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Originally Posted by Savinmoney View Post
...what thickness should the concrete board be? Thanks.
On floors, use 1/4". The only reason to use 1/2" is if, for some reason, you want the extra height.
The Following User Says Thank You to Blondesense For This Useful Post:
Old 09-24-2012, 10:06 AM   #5
as far as cutting is concerned, I use a circular saw. Make sure to cut outside as it generates a ton of concrete dust.
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
Replacing tile in bathroom floor (2x2 tile) Paul8434 Remodeling 1 09-05-2011 06:06 PM
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 06:47 PM
Failing bathroom tile floor--best options quinten Flooring 3 11-16-2010 06:56 PM
Bathroom Renovation-To Tile or not to tile jte1130 Remodeling 7 04-14-2009 10:39 AM
Help! Botched bathroom tile job steamed17 Remodeling 13 05-01-2008 09:40 PM
