Old 09-08-2006, 09:51 AM   #1
Default bathroom subfloor
my toilet is leaking and i need to replace the subfloor, does anybody know how to fix this?
jerry1967 is offline   Reply With Quote
Old 09-08-2006, 10:03 AM   #2
Master Craftsman
Big Dave's Avatar
Turn off water to toilet. Remove toilet. Remove floor covering. Remove rotted section of flooring back to a floor joist. Install blocking between joist where new and old subfloor will meet to support new and old subfloor. Replace subfloor being sure to glue and nail or screw about every 8 inches. Replace floor covering. Remount toilet. Turn water back on. Use when necessary.
Hope this helps, Dave.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Old 09-08-2006, 04:20 PM   #3
thank you very much!
Old 09-17-2006, 12:05 PM   #4
Send a message via Yahoo to Louise
Jerry, from SC?
Louise is offline   Reply With Quote
More On This Topic
Forcing the trap of the toilet is a great way to empty the toilet completely before you remove it. Forcing the trap is also a good way to unblock the drain. If something gets dropped in the toilet, too much toilet paper gets stuck or something else... Read More »
Today we are replacing a disabled toilet. It leaks and it also leaks down at the base where it’s cracked at, so we’re just going to replace the whole entire thing. If you buy a toilet that is- it’s called a toilet in a box. It has... Read More »
Toilet problems can be very expensive. Water damage to your house is a horrible thing, and if your toilet is not operating properly, an increased water bill is definitely something you want to avoid. So I’m going to tell you how to properly... Read More »
How to Remove a Toilet
How to Remove a Toilet by Expert Village
Today we’re replacing a dead toilet, one that leaks real bad. What we’re going to do is after you clean the area and get everything all prepped, you’re going to disconnect the water supply. We already have the water turned off. You just... Read More »
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Also another thing to keep in mind is taking the cover off. When you take the cover off do not set it up and down... Read More »
Rotten bathroom subfloor tallycat77 Flooring 12 02-02-2008 01:37 PM
bathroom subfloor missing mherman333 Remodeling 4 11-28-2006 08:22 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 11:06 AM
Leak in bathroom - subfloor and more DIYinNC General Discussion 1 07-01-2006 02:31 AM
Getting ready for the bathroom subfloor project scheduled for this weekend... tallycat77 Flooring 8 07-11-2005 12:50 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
