Bathroom Remodel: Hardi Solo, Hardi + Particle, Something Else? - Flooring - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 08:49 PM   #1
Bathroom remodel: Hardi solo, Hardi + particle, something else?
So I am remodeling (because it needs it) a rather small bathroom in my house. I took off the horrible vinyl tiles that were hardly adhered to the crazy thick ~1" particle board that was underneath it. The board also had the added disadvantage of raising the level of the floor in the bathroom to something absurdly over the adjacent hallway. I took the particle board up too because it was also discolored/moldy. The floor underneath that appears to be plywood and was also a bit moldy. I sprayed it down with this stuff that retards mold and mildew growth and says it will help get rid of it when already present.
Now, I want to install this type of flooring: edit for better link.
http://www.homedepot.com/webapp/wcs/...atalogId=10053
Should I put some 3/8" or 1/4" particle board on top of the existing floor, then some hardibacker, then the vinyl tile? Just hardibacker? Some plywood? I dunno, looking for advice. Thanks!
Skeletor916 is offline   Reply With Quote
Old 02-15-2009, 09:57 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 288
That link didn't work.
Are you sure the subfloor is not too far gone? What did you spray on it? If it is in good shape, you need another layer of underlayment grade plywood. Install minimum 3/8", thicker is recommended, then install your cement board into fresh thinset and fasten, tape etc. You wanna install vinyl again? You should be thinking ceramic not vinyl.
Jaz
Bathroom remodel Wolfeye Kitchen & Bath Remodeling 6 11-03-2010 04:53 PM
Bathroom Remodel MeraleeCrowl Remodeling 4 01-11-2009 08:28 PM
Steps for Bathroom Remodel? SeattleHome Building & Construction 7 10-09-2008 12:04 PM
Bathroom remodel - need advice sparky472 Remodeling 12 10-22-2007 05:03 PM
Approach to demo bathroom ceramic tile floor for remodel corky Flooring 3 01-29-2007 10:59 AM
