Old 03-07-2013, 07:23 PM   #1
beginner50's Avatar
Bathroom floors
Ok I have my living and dining room floors good!! Now what is my base layer in the bathroom floor i bought ceramic tile for it and for my kitchen floor!! What does the base need to be for both?? The bathroom is original wood under the laminate!! Kitchen is a base under carpet not sure what us under the kitchen carpet!!
beginner50 is offline   Reply With Quote
Old 03-07-2013, 07:37 PM   #2
Bathroom floors
Going to need the joist size, spacing, free spans, also what type and thickness of sublfooring you have now.
Not going to do you any good to tell you what it should be until we know what you have now.
Old 03-07-2013, 08:50 PM   #3
beginner50's Avatar
Bathroom floors
I have know idea what any of that is???
Old 03-08-2013, 03:28 AM   #4
Bathroom floors
http://www.bing.com/images/search?q=...electedIndex=3
Any tile floor can not have any movement under it or it will fail.
Old 03-08-2013, 05:31 AM   #5
Bathroom floors
I am having a new bathroom and wanted laminate. My fitter said "no" apparently even the stuff sold as moisture proof bubbles after a certain period. He said if you don't want tile get a quality vinyl instead.
brenmurphy is offline   Reply With Quote
The Following User Says Thank You to brenmurphy For This Useful Post:
oh'mike (03-08-2013)
Old 03-08-2013, 09:21 AM   #6
Bathroom floors
Bren, please go back and add your own post and not add onto someone elses.
To confusing.
Old 03-08-2013, 10:45 AM   #7
beginner50's Avatar
Bathroom floors
Ok so the flooring under the laminate is the original flooring from when the house was built. So where do I go from there??
Old 03-08-2013, 11:24 AM   #8
Bathroom floors
You need to let us know what size you floor joists are, then the thickness of the subfloor. then you need to see about the span of the floor joists.
framer52 is offline   Reply With Quote
Old 03-08-2013, 11:25 AM   #9
Bathroom floors
Is your house built on slab?
Old 03-08-2013, 11:33 AM   #10
beginner50's Avatar
Bathroom floors
Ok well I again am probably over my head here but I refuse to hire someone and learn this myself! I have no clue about a slab or no slab!! I have an unfinished basement is that where I check the joist and subfloor thickness??
Old 03-08-2013, 11:50 AM   #11
Bathroom floors
your basement is where you determine the type of floor joists. it also is where you check for the supports for the floor joists.
under where the bath is, measure the with and height of the wood.
The joists are the long boards supporting the plywood.
bathroom remodel complications megancn Building & Construction 6 07-24-2012 05:38 PM
Duct Work For Bathroom buildit45 HVAC 2 07-07-2012 10:36 PM
Remodel vs. repair bathroom slab on grade JCTeacher Plumbing 3 04-15-2012 06:54 AM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 09:37 AM
Bathroom remodel - floors before walls or vice-versa pmoe Kitchen & Bath Remodeling 2 04-08-2010 08:38 PM
