Old 10-19-2009, 12:20 AM   #1
Default Bathroom Flooring Options
I currently have some kind of fake tile over laminate flooring. No idea what is under that. The tiles are damaged and peeling up from water spilling out of the tub etc. One person I have talked to about the flooring says to just go over top of it, which I have always believed is wrong. Another said the damaged tile will need to come up, but that the new floor can be laid over what is underneath. Should the floor be completely taken down and redone or can I use one of the suggested methods?
*EDIT* Because there is frequently water splashing onto the floor, I am considering linoleum, but open to options. Also, the bathroom is relatively small, about 5 feet by 8-10 feet.
Any other suggestions about this project or it's approach would be greatly appreciated. Thanks.
Talorin is offline   Reply With Quote
Old 10-19-2009, 07:42 AM   #2
Would help if we knew what type of flooring you want to use to replace what's there now.
R&D Tile is offline   Reply With Quote
Old 10-19-2009, 12:53 PM   #3
I edited the first post to answer your question.
Old 10-19-2009, 12:58 PM   #4
I don't recommend it, but you could install vinyl over the existing floor. I suggest you tear up the existing floor and properly prepare the floor for a proper installation. I cannot tell you what is proper because I don't know what is beneath the existing surface and don't know what you intend to install. Just make sure you do it right so you avoid this problem in the future.
JK Floors is offline   Reply With Quote
Old 10-19-2009, 01:13 PM   #5
I really want the best result out of this project. Willing to go the extra mile to do it right. I am a newb when it comes to this subject, would the subfloor be the farthest you could tear down to? Would that be the best way to go?
Throwing cost/labor out the window, how would you guys do it?
Old 10-19-2009, 02:26 PM   #6
It depends on current conditions, budget, time available, and skills available. I gutted and re-built an entire bathroom when I started out wanting to fix the problem of a small section of loose tiles. The rest of the bathroom needed an overhaul anyway. The floor problem was just encouragement.
The simplest solution is to lay vinyl over your existing floor. But I don't know the condition of your existing floor. It may mean putting some leveler on the floor so the vinyl lays flat, or it may mean tearing out the entire floor. How far down? It depends on the condition of the materials below. You've had water on them. There could be rot and mold underneath. Or everything might be in perfect condition.
More On This Topic
If walking into your bathroom is like stepping out into the woods, it's time to update that 1970s bathroom. Comfortable as it was at the time, it's now dated and dingy. Keeping a few basic principles in mind, like color and style, updating the style of... Read More »
Where To Play Jacks
Where To Play Jacks by Expert Village
Hi, I'm Jamie Peterson. I'm here on behalf of Expert Village and I'm here to teach you how to play jacks. Jacks is a really fun game and it can be kind of tricky. But once you get the hang of it it's pretty easy. The first thing you need to do is play... Read More »
Athlete's foot is a fungus that can easily be transferred from one person's feet to another's through bathroom floors and linens. It is important, therefore, to keep your bathroom clean if someone in your home is infected. And once you have gotten rid of... Read More »
According to the American Academy of Allergy, Asthma and Immunology, there are approximately 40 million people who suffer from indoor allergies. You can reduce allergy symptoms by avoiding allergens that trigger your allergies. It takes only a little... Read More »
With so many styles of flooring available for your bathroom, how do you decide? Is tile your style, or is vinyl a better choice? If you are overwhelmed with the many types of bathroom flooring, here are a few tips for deciding which type is right for you... Read More »
Bathroom wood flooring options? JamesEric Flooring 6 03-28-2009 11:03 AM
New Basement - Flooring Options Debate LAX2489 Flooring 6 02-22-2009 10:03 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 09:06 PM
Bathroom Flooring? Whole House Flooring? leezarrd Flooring 8 11-28-2007 10:46 AM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 11:05 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
