Bathroom Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-19-2005, 04:02 PM   #1
bathroom flooring
Hi! My husband and I are planning to replace our bathroom floor soon. We had thought about Edge flooring, but after reading everyone's comments, I have decided that I should go with something else. The floor seems pretty level. It currently has 3/4" ply subfloor with new berber carpet :confused: ... no padding. I'm not a fan of carpeted bathrooms... it was there when we bought the house.
My concern is that I would like to have tile, but can't because our floor beams are too far apart (2+ feet) due to the age of the house. Does anyone know of any other interlocking laminate floors that would be good around all of that moisture? Or do you think I'd be better off going with vinyl linoleum flooring? I'm also curious about cork flooring. Would this be a good choice?
carebear560 is offline   Reply With Quote
Old 01-19-2005, 10:16 PM   #2
Rewards Points: 150
If you're going to be in the house for a while and you would like to have tile, then go for it. Don't do something you can 'live with'. If the floor is a bit spongey now, adding some floor joists[beams] is not a big deal. In my opinion, tile is 'the bomb' when it comes to the bathroom.
pipeguy is offline   Reply With Quote
Old 01-20-2005, 03:06 PM   #3
Thanks!
Thanks for the information you provided. I didn't know that it would be that easy to add additional support without building the floor up with additional subfloor. That is a great idea! In addition, our basement is not finished on that side of the house, so it should not be too much work to add the additional joists. I'll definitely look into doing that!!
Old 01-24-2005, 12:20 AM   #4
Red face
about floor
i have that problem before but i cross two by 6 under my floor joit to reinforce the floor maybe you can do the same
union is offline   Reply With Quote
Old 01-24-2005, 08:34 AM   #5
PRO
Glasshousebltr's Avatar
Where are ya located Carebear?
<Intro to bugle charge> GlassHouse to the rescue!
Bob
Glasshousebltr is offline   Reply With Quote
Old 01-27-2005, 10:36 AM   #6
Hello,
I am installing a "wetbed" for a vinyl shower base....does anyone know what the correct mixture for the mortar/sand mix should be.....area is approx. 4'x4'. Or should i just use a reg mortar mix then let harden and apply thinset for tile?
bighappy1 is offline   Reply With Quote
Old 01-31-2005, 08:37 AM   #7
you may want to put some hardi backer board over the floor before laying the tiles.
birddogs is offline   Reply With Quote
Old 02-24-2005, 04:38 PM   #8
Bob
We live in Pennsylvania.
Old 02-27-2005, 07:16 AM   #9
PRO
Penns a little bit of a trip to do a project, I'm near St Louis.
I guess I'll have to pospone the rescue. :D
Bob
glasshousebuilder.com
Old 07-24-2012, 08:12 PM   #10
Remember Ceramic floor tile must have atleast 1.25 inch of total floor thickness as well as additional floor joist support. As for no pad it's because pad is like a sponge and will hold moisture.
Iflooru is offline   Reply With Quote
Bathroom Flooring bbrown92y Flooring 10 05-27-2008 11:49 AM
Looking for soft flooring to put in bathroom for elderly lady pyrowolf Flooring 8 04-28-2008 04:25 PM
Bathroom flooring (tile?) Nhrafan Flooring 30 06-11-2007 12:44 PM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 10:05 PM
Laminate Flooring - Is It Installed Under Bathroom Cabinets? BDPNA Plumbing 92 02-07-2007 01:02 PM
