Bathroom Floor Water Damage. - Flooring - DIY Chatroom Home Improvement Forum
Old 05-19-2007, 11:58 AM   #1
Bathroom floor water damage.
Hello
I have some water damage to the subfloor underneath my tile. I pulled up the tile to exposed the water damaged area. My intention was to cut out the damaged area replace it and put the tile back.
I drilled a hole in the subfloor (I am not sure this is the correct term) and it appears to be 2 sheets of 3/4" plywood. My question is do I need to cut through both sheets, or can I just remove one layer?
I will use a circular saw to cut the floor. Any suggestions on how to cut the floor next a wall or in a tight corner?
I appreciate any advice, thanks!
makisushi is offline   Reply With Quote
Old 05-19-2007, 12:08 PM   #2
jproffer's Avatar
Rewards Points: 716
You can cut through one at a time and see what the second layer looks like. Set the blade depth a shade under 3/4".
As far as the corners and close to the walls, a circular saw won't do it. If the subfloor is rotten that close to the wall you will have to use a demo saw, in which case you won't be able to cut through just one layer.
jproffer is offline   Reply With Quote
Old 05-19-2007, 01:48 PM   #3
Rewards Points: 77
Rent a toe kick saw for close to the wall or if you have lots of $'s get a Fein multi-tool.
Zero Punch is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
