Old 08-19-2010, 10:21 AM   #1
Bathroom Floor Tile Questions
I have a small (7x5) bathroom that currently has those stick down adhesive backed vinyl tiles in it. I would like to replace the floor with ceramic tile as a start to a bathroom remodel but have some questions.
1. I was planning to remove the tile and then lay cement backerboard down over it as a solid base for the ceramic. I then heard that it is too hard to get the tile and adhesive off and that I should tile over the vinyl. Input?
2. If I get the vinyl up and put a cement board down (3/8") along with tile (1/4"-3/8") will I have trouble with the toilet sealing on the wax ring correctly or with the tile/carpet transition under the door (I have clearance)?
3. Should I take the tile and the wood base out and replace with just a cement board?
Any help would be greatly appreciated!
BaconK5 is offline   Reply With Quote
Old 08-19-2010, 10:34 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Need a lot more info. What thickness is the plywood on the floor? What size floor joists do you have? What is the distance between them? How far do they span?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 08-19-2010, 10:36 AM   #3
Im going from memory, but I believe the plywood is 1/2", the joists are 2x10s and I think the spacing was 12 or 16"
gutted bathroom, have some questions and looking for ideas fabian Kitchen & Bath Remodeling 15 01-27-2009 09:23 PM
my bathroom set up, and questions fabian Electrical 4 01-26-2009 09:24 AM
two easy bathroom drywall questions amakarevic Building & Construction 2 04-30-2008 10:17 AM
bathroom remodel questions Jeff32 Remodeling 2 08-13-2007 11:36 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 08:59 AM
