Bathroom Floor Replacement - Flooring - DIY Chatroom Home Improvement Forum
Old 09-14-2012, 03:31 PM   #1
Hello,
I just finished gutting my upstairs hall bath and I'd like to know the proper materials to use in preparation for a sheet vinyl install. I'm down to the 2x material and need to come up 3/4" to match the height of the adjoining hallway floor. What I removed was some sort of cement/mortar board with wire backing (circa 1969).
Do I start out with 1/2" plywood, followed by 1/4" underlayment?? What are the recommended procedures and materials?
Thanks,
Gene
Gene Labbé is offline   Reply With Quote
Old 09-14-2012, 09:52 PM   #2
Rewards Points: 1,678
Originally Posted by Gene Labbé View Post
Hello,
Thanks,
Gene
I'd prefer a good grade of 3/4 ply and a thin underlayment if underlayment is even needed. Sheet vinyl over concrete seems to do just fine so I'm really not seeing it necessary over ply. But the manufacturer of a particular product may have a reason to do so. Check with them on underlayment if possible.
Old 09-14-2012, 10:02 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 146
You need 3/4" ply and 1/4" underlayment for sheet vinyl.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-14-2012, 10:53 PM   #4
Thanks Rusty. Forgive me if this is a silly question, but is the 1/4" underlayment simply plywood, or is it some other type of product?
Thanks again, Gene
Old 09-15-2012, 01:01 AM   #5
Rewards Points: 264
I agree. Use 3/4" plywood with 1/4" underlay. I believe they type you want is called luan.
Awoodfloorguy is offline   Reply With Quote
Old 09-15-2012, 07:01 AM   #6
I don't know if lauan is a good idea for a bathroom. If it get wet, it will swell. Even with vinyl sheet, I think a 1/4" cement backer board would be a better choice.
I just did porcelain tile on my breezeway over cement backer board. I'm doing my kitchen and bathroom next.
There is also Ditra, which looks like it might be good for a wet area. Not sure about that though.
aerobatty is offline   Reply With Quote
Old 09-15-2012, 08:19 AM   #7
Rewards Points: 14,000
It's 3/4 Tongued and groved underlayment rated Plywood or better yet Advantec subflooring, with constrution adhesive on top of the floor joist.
It's nailed every 6".
Then 1/4 rated A/C underlayment rated plywood, not Louon!
Most manufactures of vinyl floor state in the install directions not to use louon, it can cause glues to reliece and color bleed through.
The under layment needs to be attached every 4" on the outsides and every 6 to 8" in the field. When installing it there's no glue used, the seams must not line up with the seams below it in the subflooring. DO not nail it through the floor joist.
Once it's installed any gaps, and flaws need to be filled with floor leveler
Never concrete tile board under linolum.
Old 09-15-2012, 05:14 PM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
Don't use backer board and luon does not come in 1/4". Joe got it with A/C ply 1/4"
JetSwet is offline   Reply With Quote
Old 09-15-2012, 05:44 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 412
All these different opinions.....isn't the internet fun!
Years ago luaun ply was the standard as the underlayment for vinyl, no more, mainly because of what Joe said;
It's also soft and leave indentations, plus moisture makes it disintegrate.
Each manufacturer has directions on what to use, follow them. A/C ply is probably one choice. Another is a products call Multiply, there are more.
We also have a newbie recommending concrete backer and even Ditra. He/she probably missed the part where you stated;
So, I say 3/4" subfloor grade ply or OSB, (glued/screwed), then 1/4" A/C or Multiply or equal, then your vinyl. But read the instructions first.
BTW, what you removed was not concrete board, it was a mud-job, mixed and placed on the job.
Jaz
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
