Bathroom Floor Question - Flooring - DIY Chatroom Home Improvement Forum
Old 12-11-2007, 09:08 PM   #1
Bathroom floor question
We have 1X1 inch tiles on our bathroom floor.
Circa 1969.
My Spouse plans to put laminate tiles over this concrete tile.
I was under the assumption that this old tile must be removed down to the concrete slab, before laying down
any new flooring.
Are there any initial steps (grinding/sanding etc) I should learn about before he begins?
Thank you in advance.
Junebug is offline   Reply With Quote
Old 12-12-2007, 01:09 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro tile man, but until one comes along, you can get some great info from John Bridge's tiling website at http://www.johnbridge.com/
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-12-2007, 01:24 AM   #3
s0lidgr0und's Avatar
Personally, I'd never place a new floor over the top of something like ceramic tile. Especially ones from 1969.
s0lidgr0und is offline   Reply With Quote
Old 12-12-2007, 03:31 AM   #4
jhen
Spammer - Edited
jhen is offline   Reply With Quote
Old 12-12-2007, 11:09 AM   #5
What do you mean by laminate tiles?
NateHanson is offline   Reply With Quote
Old 12-12-2007, 09:45 PM   #6
Here is a link to a description:
http://www.homedepot.com/webapp/wcs/...cStoreNum=8125
I still think the existing tile will need to be removed.
Would Pergo work over tile?
My Spouse seems to think it would be too hard to
install Pergo around the toilet because of the difficulty
of cutting the wood to fit around the base.
Just trying to avoid removing the tile. I think that would be too big of a job and we only have 1 bathroom with a shower.
I thought of carpeting, does anyone think that would be a good idea??
We could get a thick floor rug to lay over the carpet when we come out of the shower...
Old 12-13-2007, 03:02 PM   #7
I just finished replacing all of the tile from the downstairs powder room -- it really isn't too bad. Get a heavy hammer and go after it. I'm always a fan of removing the existing flooring before adding more.
Funny side story to this -- after pounding away at the old floor with a hammer and replacing it with new travertine I was putting up wall hangings. My 2 year-old saw the hammer on the floor and .... started pounding away on the new travertine . Fortunately, I grabbed the hammer before she did any damage. She knew just what to do with a hammer and floor tile
Good luck!
StevePM is offline   Reply With Quote
Old 12-13-2007, 04:18 PM   #8
You should be able to use a small jack hammer style tool with a wide flat blade. You go under the tile with this tool and the tiles should break free.
If it is a smaller bathroom then a wide chisel and hammer should help "pop" up the tile.
The first few tiles that you remove should tell if it will be a easy task.
redline is offline   Reply With Quote
Old 12-13-2007, 07:16 PM   #9
Rewards Points: 150
One bathroom....Guy in the house...Thick carpet...Nuff said
mike costello is offline   Reply With Quote
Old 12-16-2007, 01:38 AM   #10
Any thoughts on this?
Old 12-16-2007, 08:28 AM   #11
A carpeted bathroom is a terrible idea in my opinion. Bathrooms should be easy to clean.
Pergo would be no harder to install around the toilet than the laminate that you posted a link to. They're basically the same type of product. They're a plastic laminate that snaps together and floats over the old floor.
With any floor you're going to remove the toilet. Leave a gap around the toilet flange, and then reinstall the toilet. The flooring can be pretty sloppy around the flange, since the base of the toilet covers a fair amount of floor around the flange.
Old 12-16-2007, 11:36 PM   #12
Thank you for the insight. I had a feeling Pergo would work, since an underlayment is placed between the old floor and new Pergo.
Old 12-17-2007, 09:34 AM   #13
Personally I'd be worried about using any floating type floor in a bathroom, because of the possibility of getting moisture under the floor, which seems inevitable to me.
Tile is my choice, but the speed of a floating laminate is certainly attractive.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
New bathroom advice urgently needed EddieLeonard General DIY Discussions 4 10-05-2007 03:45 PM
Second level / attic bathroom size moneymgmt General DIY Discussions 2 05-02-2007 07:32 AM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-22-2006 11:03 PM
