Bathroom Floor Preparation For Tiling - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 12:11 PM   #1
Bathroom floor preparation for tiling
Hello,
I'm new here, currently working on my new house 2nd floor bathroom and have finished tearing everything apart. Attached is a picture of my subflooring. So after a lot of reading and research, my plan is this:
1. Screw any loose wood panels to the joists.
2. Install OSB 1/2" boards on the floor (making sure not to screw them into the joists – is this the correct way?) leaving 1/4" gap from the walls and 1/8" between the panels, staggering them perpendicular to the joists.
3. Apply unmodified thinset and screw hardibacker (1/2") boards on top, 1/4" gap from the walls, 1/8" gap between the board.
Questions:
1. My first question is: Does this plan have any flaws?
2. Then, I'm not sure what kind of screws to use in steps 1 and 2 above. As for OSB, I've read that deck screws #8 1 1/2" are ok. Can you let me know if I'm wrong?
3. Also, I’m wondering if I should be worried about adding too much total weight by adding OSB, thinset, hardibacker and tile on the floor.
I’d appreciate any of your thoughts…
ps. picture was taken earlier, i've allready removed old tile completely.
darius is offline   Reply With Quote
Old 05-11-2012, 06:42 PM   #2
DIY staff
Rewards Points: 7,174
After you have made sure that the old subfloor is secured well---use BC exterior grade plywood--
{Exposure 1}
OSB is less stable than plywood---as to the screws and such--I'll leave that to others to answer.
I prefer Wonder board and Durrock (1/4") over Hardi Backer---Mike--
Old 05-11-2012, 06:45 PM   #3
Rewards Points: 13,712
Ceramic coated decking screws to attach the plywood.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 04:49 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 10:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 09:47 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 07:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 11:43 AM
