Bathroom floor preparation for tiling
1 Attachment(s)
Hello,
I'm new here, currently working on my new house 2nd floor bathroom and have finished tearing everything apart. Attached is a picture of my subflooring. So after a lot of reading and research, my plan is this: 1. Screw any loose wood panels to the joists. 2. Install OSB 1/2" boards on the floor (making sure not to screw them into the joists – is this the correct way?) leaving 1/4" gap from the walls and 1/8" between the panels, staggering them perpendicular to the joists. 3. Apply unmodified thinset and screw hardibacker (1/2") boards on top, 1/4" gap from the walls, 1/8" gap between the board. Questions: 1. My first question is: Does this plan have any flaws? 2. Then, I'm not sure what kind of screws to use in steps 1 and 2 above. As for OSB, I've read that deck screws #8 1 1/2" are ok. Can you let me know if I'm wrong? 3. Also, I’m wondering if I should be worried about adding too much total weight by adding OSB, thinset, hardibacker and tile on the floor. I’d appreciate any of your thoughts… ps. picture was taken earlier, i've allready removed old tile completely. |
After you have made sure that the old subfloor is secured well---use BC exterior grade plywood--
{Exposure 1} OSB is less stable than plywood---as to the screws and such--I'll leave that to others to answer. I prefer Wonder board and Durrock (1/4") over Hardi Backer---Mike-- |
Ceramic coated decking screws to attach the plywood.
| All times are GMT -4. The time now is 09:36 AM. |
