Bathroom Floor Finish - Flooring - DIY Chatroom Home Improvement Forum
Old 01-19-2012, 08:08 AM   #1
I want to lay a laminate product in my bathroom, any product labeled "water resistant" should work correct?
I have seen a vinyl plank product also is this suitable it appears that the stick to each other via an extended lip on the edge of each piece.
Couple of other questions, will resin paper suffice as an underlayment, this is a small bath. Also the tub is an irregular shape at the base and the laminate will have to be scribed and cut with a jig saw to fit. Are there any issues with using clear silicone on the first piece against the tub?
Joe Tilghman is offline   Reply With Quote
Old 01-19-2012, 11:49 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Joe Tilghman View Post
I want to lay a laminate product in my bathroom...
Until water runs on it. Maybe.
No laminate product should be used for a floor INTENDED to get wet...
or even for floors with a high likelihood of getting wet. It's that simple.
If you don't want the expense of tile... go with sheet vinyl.
Old 01-19-2012, 11:56 AM   #3
Thanks for the reply
Old 01-19-2012, 12:00 PM   #4
Rewards Points: 12,812
Laminite has to be able to expand and contract or it will pull apart at the seams. Hows it going to do that with a toilet bolted to it.
The seam around the tub area will be the first spot for water to get in under the flooring.
Old 01-19-2012, 02:38 PM   #5
Looks like ceramic is my option then.
Best option for Bathroom Ceiling Paint? tealab Painting 7 04-05-2013 05:49 PM
Exhaust Vents - Bathroom and Stove trophywalleye HVAC 0 03-19-2011 11:14 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement Bathroom Circuit PJ33P Electrical 1 02-12-2011 08:13 PM
Bathroom tile question aumanpj Building & Construction 66 07-18-2009 12:43 PM
