Old 04-03-2006, 07:28 PM   #1
bathroom floor
I just tore up the tile in my hallway bathroom and plan on replacing it with a vinyl floor. The problem is that when I tore up the tile, it almost looks like there is concrete under it and there are places where the "concrete" has come up and is no longer level. What type of subfloor should I put down to remedy this before I lay the vinly??
I also plan on removing the vanity and replacing it with a Pedastal sink, putting in a new toilet and doing a "Tub surround: on the bathtub and tile...
Thanks for any help you can give!!!
RemodelingMom is offline   Reply With Quote
Old 04-03-2006, 09:46 PM   #2
Floorwizard's Avatar
bathroom floor
Tile should be mounted on a concrete substrate.
That needs to come out.
then reinstall at least 3/8 plywood AC for a vinyl substrate.
then install vinyl.
good luck MOM
Floorwizard is offline   Reply With Quote
Old 04-03-2006, 10:50 PM   #3
bathroom floor
Thank you so much, I will work tomorrow night on taking up the floor before laying the plywood! You have been a great help!
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
bathroom floor looks bad!! drb Flooring 13 03-10-2007 09:19 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 02:39 PM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 08:03 PM
Exploring bathroom addition on second floor wease Plumbing 12 12-10-2006 11:20 AM
