Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-09-2013, 10:34 PM   #1
Bathroom floor
So I'm pulling up the tile in the bathroom and in the process the cement board is getting damaged. I'm assuming this needs to be replaced? Do I put plywood under the cement board? How do I fasten them? What about a toilet flange? What about thickness? Thanks
matt13 is offline   Reply With Quote
Old 04-09-2013, 11:29 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Yes it should be replaced in this case if it is dinged up pretty good.
Is there not plywood under now?
Old 04-09-2013, 11:41 PM   #3
Yup it's pretty bad. There is no plywood under the concrete. The house is a pier and beam built in the early 40's. this is a real can of worms I've opened! Lol
Old 04-10-2013, 08:15 AM   #4
Rewards Points: 13,300
Old house, bathroom, of cource it's a can of worms. It always is.
Undersized joist, to long a span, spaced to far apart, 1 X 6 subflooring, plumbing running right through big holes cut in the joist.
Fungus growing on the joist, no flange on the toilet, supply lines coming up through the floor instead of the walls, no vent, old steel and cast iron rusted out plumbing, shut offs no longer work.
Tile over old plaster or sheetrock with no water proofing.
All the joys and to be expected when working on an old house.
Old 04-10-2013, 10:53 AM   #5
Lmao!!! Yup the lengths people go to in order to half ass something. I'm glad I'm not the only one in this boat.
Old 04-10-2013, 12:09 PM   #6
I've seen tile layed over hardwood floors, linolium, louon, partical board, 5/4 decking boards.
All failed.
Old 04-11-2013, 05:14 AM   #7
An old Tradesmen
Rewards Points: 6,556
Moved to Flooring forum.
Old 04-11-2013, 08:10 AM   #8
Rewards Points: 4,792
Cement board is not really a structural element. The joists and subfloor must provide all the stiffness you need. If your floor isn't sturdy, then you should rip out all the cement board and then put down additional plywood.
Cement board accomplishes a few things, like being a good surface to bond to, creating a flat surface (assuming thinset was properly applied beneath it), and having a shrinking and expansion rate closer to tile than plywood.
If you're going to rip it out, I'd use Ditra instead of cement board. It has a lot of advantages.
jeffnc is offline   Reply With Quote
Old 04-11-2013, 08:46 AM   #9
Thanks for the tip. Ill be tearing everything out and replacing the bad.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
no framing concrete slab bathroom floor needs to be repaired in one spot barrr Flooring 1 05-15-2012 10:01 PM
Help with ceramic floor bathroom lornescot Flooring 0 11-19-2011 01:35 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 03:17 PM
