Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-18-2013, 11:05 AM   #1
bathroom floor
hi Im going to be doing a full reno in bathroom tiles tub surround toilet u get the drift i have a question on walls in shower and floors . as for walls in shower i have ditra for the waterproofing what should i use for the walls it self can i use drywall or do i need cement board..2nd floors im tiling the floors and theres just laminate down now will be pulling it out but need to lay tile down house is 15yrs old and just wondering what my options are for the floor nothing physically wrong with floor can i put ceramic right on it or should i use a sub
thanks jay
porsha is offline   Reply With Quote
Old 02-18-2013, 01:11 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
thanks jay
You can use drywall for the shower because if you install the Kerdi membrane properly there will be no water that will get behind it.
As far as the floor tiles....
I used 1/4" durarock layed down over my subfloor when I installed slate a few years back. You will want to know what you have as subfloor now. Pull up a register and measure the thickness, also everyone on here will want to know the size of your floor joists, the center to center spacing, and the span of the joists as well. This will be to properly assess the deflection of the floor. If your floor is not adequately supported your tiles will crack.
I know it is a lot of information and you are probably thinking "Well a nice yes would have worked the best" but all this information is needed to help you with a proper install.
brockmiera is offline   Reply With Quote
Old 02-18-2013, 02:28 PM   #3
Ok thanks about the wall was just wondering cause people talk about cement board and or durock but yes I'm using kerdi on it as for floor I don't know yet I'm just thinking and looking ahead not working on it till march break but what I can see lol is 3/8 ply and looks like lol they put a 1/4 inch sub which looks like mdf never seen that before
no framing concrete slab bathroom floor needs to be repaired in one spot barrr Flooring 1 05-15-2012 09:01 PM
Help with ceramic floor bathroom lornescot Flooring 0 11-19-2011 12:35 PM
Bathroom floor & shower waterproofing questions hotbread Tiling, ceramics, marble 0 01-24-2011 12:39 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
