Bathroom Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 09:18 AM   #1
bathroom floor
have one rotted spot in the corner by the tub.
There is non treated plywood down,can i just go over it with treated plywood or should i tear the whole floor out and start from scratch.
mark marabella is offline   Reply With Quote
Old 01-23-2013, 09:26 AM   #2
DIY staff
Rewards Points: 7,174
How rotted? How thick is the new ply going to be?
What do you mean by 'treated'? BC exterior glue is the usual choice --green treated ply is not good for flooring.
mark marabella (01-24-2013)
Old 01-23-2013, 09:29 AM   #3
Rewards Points: 14,014
Treated plywood is never used inside a home.
It's never a good Idea to lay anything over rotten wood.
I only use Advantec for subflooring, stronger, no voids, far more water resistant.
Old 01-23-2013, 09:57 AM   #4
it just a small hole 3 inch by 3 inch from the water running down the tub after a shower,should i still tear it all out.none of the plywood is wet.what you think i should do?
Old 01-23-2013, 10:13 AM   #5
flooring
small spot in corner of tub 3 inch by 3 inch from the water running down after showers.The rest of the floor is dry
Old 01-23-2013, 10:46 AM   #6
Tileguy
JazMan's Avatar
Rewards Points: 412
Sorry, but that's really hard to believe. Wood does not just rot and then 1/4" over is perfect. Try driving some nails near that spot.
If it is only a 3" spot, you can just install 3/8" or thicker ply over the old.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
Old 01-23-2013, 11:49 AM   #7
Rewards Points: 4,796
One time I saw a situation similar to that under the corner of a bath. Maybe a 4" hole, soft wood a couple inches beyond that, then apparently perfect. To this day, that is a mystery to me.
jeffnc is offline   Reply With Quote
The Following User Says Thank You to jeffnc For This Useful Post:
no framing concrete slab bathroom floor needs to be repaired in one spot barrr Flooring 1 05-15-2012 09:01 PM
Help with ceramic floor bathroom lornescot Flooring 0 11-19-2011 12:35 PM
Bathroom floor & shower waterproofing questions hotbread Tiling, ceramics, marble 0 01-24-2011 12:39 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 01:25 PM
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 02:17 PM
