Basement Tile Job - Flooring - DIY Chatroom Home Improvement Forum
Old 07-30-2007, 11:30 AM   #1
d&g
basement tile job
can i lay ceramic tile directly to the basement floor. or do i need to use a backer board?
d&g is offline   Reply With Quote
Old 07-30-2007, 01:42 PM   #2
RippySkippy's Avatar
Assuming your basement floor is concrete, you should use an uncoupling membrane. I've seen it at HD for about $1.65/ft2.
RippySkippy is offline   Reply With Quote
Old 07-30-2007, 02:10 PM   #3
but people also lay directly onto concreteand didn't have problem also... but membrane is kind of a guarantee thing to make the job more solid with added vapour barrier effect....
KUIPORNG is offline   Reply With Quote
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
Basement flooring. Tile? HuskySkull Flooring 1 08-10-2007 11:45 PM
Tile on basement floor Sarge Flooring 12 07-05-2007 07:41 PM
Adding toilet in basement with tile on the floor Kyle Plumbing 6 09-13-2006 08:59 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
