Basement Subfloor When Slab Has Xps - Flooring - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 08:31 PM   #1
Rewards Points: 640
basement subfloor when slab has xps
I found out that my basement slab has 3" of XPS foam under the concrete before you get to the gravel.
I wanted to put 1"+ of XPS down on the slab to insulate it before I found this out, I still want to make it a little softer and put a plywood subfloor down. Would it be ok to take it down to 1/2" of XPS like the barricade subfloor tiles have since insulation and vapor entry aren't really a concern now that I know about the XPS
BlueBSH is offline   Reply With Quote
Old 01-24-2012, 08:52 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 112
Putting plywood on a slab is a bad idea no matter how you do it.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
Ditra over basement slab? Trustmemalawyer Flooring 1 08-12-2011 05:58 PM
2X4 Framing on sloped basement slab chobio Building & Construction 2 07-02-2011 08:11 AM
bathroom basement subfloor on concrete slab Gus72 Building & Construction 9 01-19-2008 05:57 PM
Concrete basement slab + Radiant + Tile MageMinds Flooring 4 08-21-2007 12:52 PM
