Basement Subfloor - Vapour Barrier - Flooring - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 01:20 PM   #1
Basement Subfloor - vapour barrier
I'm in the process of installing a subfloor in the basement. Floor is dry and does not get water. the concrete floor is slanted towards the floor drain about 2" over a 12' span. So I was planning on lying down 2x3 and shimming them to level the floor, and then 5/8 OSB gold edge on top.
1) Should I first lay down a product like Delta FL and the 2x3 on top of that?
2) Is using 2x3 laid flat shimmed every 12" ok ??
thanks
Steve
dodge1930 is offline   Reply With Quote
Basement vapor barrier over mirror drain eubarch Plumbing 0 09-27-2011 09:57 AM
basement insulation - vapor barrier help please! cluelessloser Insulation 5 04-08-2011 03:49 PM
Basement mystery-insulation/vapor barrier bergerdude Carpentry 7 04-01-2010 12:08 PM
Basement Framing vapor barrier emccarthy2 Building & Construction 2 03-24-2010 06:35 AM
Basement Insulation / Vapor Barrier Question Krendler Building & Construction 0 02-24-2010 05:29 PM
