Basement Subfloor Comparison - Flooring - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 12:43 AM   #1
Would anybody know the difference between Delta-FL (http://www.cosella-dorken.com/bvf-ca...roducts/fl.php) versus using Superseal All-In-One? (http://www.superseal.ca/all_in_one_subfloor.html) They seem to be the same thing to me, and Delta-FL is available locally.. But Delta says if I intend to use carpet, I must use T&G Plywood on top of it.. whereas the Superseal says I don't have to use T&G Plywood on their product. What's the difference?
casper129 is offline   Reply With Quote
Old 03-15-2011, 06:17 AM   #2
DIY staff
Rewards Points: 7,174
What are you trying to accomplish?
Do you have a moisture problem? If so,how bad?
Old 03-15-2011, 07:49 AM   #3
Nope, no moisture problems in my basement, but with the house only being 20 years old, I figure I might at well put this down first before I start to remodel my basement, incase I develop a tiny leak in the springtime at the bottom of my foundation.. just basically piece of mind type stuff, but I don't want to shell out the $6 for a 2'x2' piece of DriCor...
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Basement Cooling BTU requirements? neilt HVAC 5 05-29-2010 03:26 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
