Basement Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-18-2011, 01:28 AM   #1
Basement Subfloor
The basement subfloor I need to build is 11'x10'.
I dont know how to run the 2x4s across the cement slab in a staight line.
Do I need to buy 10' 2x4s or how should I connect the 8' 2x4s?
It seems I know many things except the simplest.
Thanks!
The Plan:
6 mil vapor barrier overlapped and 4" up walls
rigid floor insulation
2x4 sleepers spaced 16" on center
23/32" t&g OSB perpendicular & staggered seams 1/8" gaps all around
mikesfloor is offline   Reply With Quote
Old 01-18-2011, 05:14 AM   #2
Rewards Points: 200
What are you installing on the OSB ?
Floor Doc is offline   Reply With Quote
Old 01-18-2011, 02:35 PM   #3
Not quite sure.
If it stays storage, then nothing or something cheap like masonite.
If I need to finish it, then whatever I can get cheap on craiglist.
Right now the plan is that it will be a low use room.
Old 01-18-2011, 02:47 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
.....and what is wrong with it the way it is? Why do you feel a need to improve the floor?
XXX
Old 01-18-2011, 03:00 PM   #5
It is really cold in there.
Think North Washington state and 6' below grade.
It is on my to do list.
It would increase value of home... blah blah blah
Old 01-18-2011, 07:29 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 412
......and chances are you'l be creating a "mold-trap". Building a subfloor over below grade concrete covered with plastic sounds nuts to me.
Jaz
Old 01-18-2011, 11:37 PM   #7
So then what?
*Opens door for constructive ideas
Old 01-19-2011, 06:51 AM   #8
Rewards Points: 154
dri-core or equivalent
awdblazer is offline   Reply With Quote
Old 01-19-2011, 01:11 PM   #9
The floor is not the levelest floor, and this was very interesting:
http://www.cqs.com/homeqa/dricore.htm
The Following User Says Thank You to mikesfloor For This Useful Post:
Jackofall1 (01-19-2011)
Old 01-19-2011, 01:53 PM   #10
Experienced
Jackofall1's Avatar
I would imagine the best way to insulate and build a sub-floor on subgrade concrete would be similar to that of insulating walls below grade. 2" XPS, directly to concrete, followed by sleepers, then a sub-floor material such as OSB or plywood.
http://www.homeconstructionimproveme...oncrete-floor/
Similar to what you had originally though minus the plastic.
Putting plastic directly on concrete is not wise as it creates an opportunity for moisture to pool and then having no where to go, you really want the concrete to as they say, "Dry to the Inside".
Mark
The Following User Says Thank You to Jackofall1 For This Useful Post:
mikesfloor (01-19-2011)
Old 01-19-2011, 05:44 PM   #11
Okay, that makes sense. Thank you Mark.
XPS-> sleepers->OSB
How do I lay 8ft sleepers in an 11x10 room?
Tags
2x4 , basement , joist , subfloor
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 07:36 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 01:17 PM
Basement subfloor and Radon - ideas? globus999 Building & Construction 4 06-16-2010 01:38 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
