Basement Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2013, 08:27 AM   #1
basement subfloor
Are there any other options out there close to this that are a little more reasonably priced? At 2.50-3.00 a square foot (yes I know they come in 2X2) that seems a little expensive to me. Maybe I am way off here. Any comments or suggestions are welcome.
lk00331 is offline   Reply With Quote
Old 08-08-2013, 09:36 AM   #2
Rewards Points: 13,444
Depends on what type flooring your planning on.
Old 08-08-2013, 09:49 AM   #3
more than likely carpet. the basement is dry but just in the rare case that a little leak springs I would like the security of knowing that the carpet/padding will be safe.
Old 08-12-2013, 09:28 AM   #4
You can use a plastic subfloor instead. I used DELTA-FL (available at Lowe's). It is a stronger plastic subfloor that allowed me to install engineered flooring on top of the plastic subfloor without using a wood subfloor in between. I had considered carpet and when I priced DELTA-FL and adding the wood subfloor myself it was about half the price of the 2x2 panels with wood.
BrianAM is offline   Reply With Quote
The Following User Says Thank You to BrianAM For This Useful Post:
lk00331 (08-12-2013)
Old 08-12-2013, 10:37 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Hope you don't get too much mold under the plastic.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 08-14-2013, 10:55 AM   #6
If the floor is cleaned and all organic material removed (i.e. wood shavings), no mold will grow. Mold needs something organic to grow. Plastic isn't organic and will not cause mold to grow.
Old 08-14-2013, 11:06 AM   #7
Rewards Points: 274
Plastic is appropriate in this regard.
alexjoe is offline   Reply With Quote
How to - prevent basement mold crazymountain How To Guides 36 07-23-2014 06:02 PM
Subfloor and P-trap for basement bathroom svaic00 Plumbing 9 10-11-2012 12:51 PM
Basement Subfloor Fandu Insulation 1 09-08-2012 09:34 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 05:18 PM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 01:17 PM
