Old 05-03-2011, 10:58 AM   #1
basement subfloor
I'm remodeling a basement with a steeply sloped, painted slab floor. I need to level it in a few places. I want to maintain precious inches of headroom. I'll use common cementitious self-leveling patch in areas where i can easily grind paint off. But to avoid grinding the entire floor i want to build a subfloor but it will have to transition from 1/4" (or less?) to 2 1/2". I planned use Delta FL with landscapers cloth underneath for sweaks then layers of OSB/Plywood to acheive appropriate heights. And then use some kind of leveling compund on top to transition the seams. i plan to put closed cell pad and carpet throughout. Any and all advice, ideas, info are welcome. Thanks
Alan2011 is offline   Reply With Quote
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
How to solve problem of moist basement walls moist Building & Construction 4 08-30-2010 06:18 PM
Basement sloping and subfloor install - question globus999 Building & Construction 2 06-17-2010 02:17 PM
Basement subfloor and Radon - ideas? globus999 Building & Construction 4 06-16-2010 02:38 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
