-   -   basement stairs (http://www.diychatroom.com/f5/basement-stairs-165879/)
bote110 12-07-2012 10:59 PM
basement stairs
My contractor made Temp Basement Stairs and now I have to finish with Pine Threads and Risers , What should I use nails or screws and what type?
Does the Risers go on first then the Stairs ? Do I start from top an work my way down. This is one of many first time projects I have to do wish me luck.
BigJim 12-07-2012 11:13 PM
Start at the bottom or you can start from the top installing your risers and work your way down, install the treads after the riser. Glue all edges where wood touches wood and use a good construction for the tread to stringer. Hand nailing use 10d finish or you can use trim screws. A nail gun use 2 inch nails.
bote110 12-08-2012 03:34 AM
My temp stairs are build with walls going down to a door to the basement, I thought you just pop off the Threads and replace with new pine Threads and Risers but what if I had to add a Skirt board?
joecaption 12-08-2012 07:43 AM
The stringers were suppost to have a 2 X 4 as a spacer on the outside of them where it goes againt a wall to allow room for the skirt and the sheetrock to slip in behind it.
Sheetrock goes in first, skirt then the risers and treads.
I disagree with where to start. I always start at the bottom and work my way up. Reasons being, that way I have a place to sit while working and a something to walk on when going to get and cut materials.
If there's anyway you can get your hands on a 12" sliding mitre saw do it.
Sure makes it a lot easyer to cut the treads in one swipe.
When ripping the treads to width set the table saws blade at a very sight angle. This will minumize the wood to wood contact so the tread will fit tighter.
I only use constrution adhesive when attaching, not glue. I predrill a pilot hole and use galvinized finish nails, reason being the rough finsih on the nails holds great.
Before doing anything make 100% sure those stringers they threw in there meet code for width, run and rise and number of them.
There's been dozens of posters on here asking how to fix all the gaps, make the stairs stronger, get rid of squecks, make them to code after there already done.
If the treads are going to be stained and the rizers and or skirts are going to be painted I like to stain the treads before installing. That way no tape is needed and no stain gets on the other pieces.
BigJim 12-08-2012 10:35 AM
Joe pretty well nailed it. If the stringers are against the wall now, instead of spaced out, you can make a template and cut the skirt to fit the stringer.
bote110 12-08-2012 06:43 PM
I notice there is a "2x"4 on the side of the stringers with the gap between the sheet rock and the stairs. The treads are temp with 2 nails each the stringers are to code , they had to be redone for building inspection . Does the Skirt Board get screw on to wall to each stud then cut each thread and risers to fit in? is like a "1/4 or "1/2 inch board?
joecaption 12-08-2012 09:23 PM
Were going to have a picture to make sure were all on the same page.
The skirt is most often a 1 X 6 clear pine board. And yes it's nailed to the studs.
joecaption 12-08-2012 09:28 PM
This may help, I find cutting the skirts to be a challange.
http://www.thestairguy.com/
BigJim 12-08-2012 09:54 PM
Joe a 1X6 won't work for a skirt, I always used a 1X12. Cutting a skirt isn't that hard, some are a little more work than others though. If you need help with the skirt let us know.
You can nail the skirt to the studs, that way you won't have such large holes to fill.
bote110 12-08-2012 11:54 PM
Now we are talking about nailing them to the wall studs right? How are the Skirt Board cut at the top and bottom of the Skirt Board?
BigJim 12-09-2012 08:11 AM
Yes nail the skirt to the studs, there is nothing else there to nail to.
Here are a couple of links to explain how to cut a skirt, I am not awake enough to explain it yet.
http://www.thisiscarpentry.com/2011/...-skirt-boards/
http://webtools.delmarlearning.com/s...6_p507-539.pdf
If you need help we will check back.
