Basement Stair Redo - Flooring - DIY Chatroom Home Improvement Forum
Old 09-16-2012, 06:26 AM   #1
Basement stair redo
Hi there. We are refinishing our basement, and the last part, which we can't figure out how to handle, are the 60-year-old stairs. These have very-aged sheet linoleum on them with metal nosing. They definitely are old and dingy, and since the basement holds our guest room, and this would be the first thing the guest sees, I want something more inviting.
However, I'm a little squeamish about unleashing the nastiness of pulling up the linoleum and sanding off the glue (which is now black and nasty). Are there other options? I don't really want to do more peel and stick on top of it. Can I nail into it? I had thought of doing stained wood treads, and painting the linoleum risers (which are in much better shape), or recovering the whole thing in wood and just leaving the linoleum in place. We have a router and other tools to custom-make parts, so that isn't a problem.
Any suggestions?
NoleGeoGirl is offline   Reply With Quote
Old 09-16-2012, 07:49 AM   #2
Rewards Points: 13,732
Post a picture of what you have.
If the runs and risers are to code then the best look would be to remove all of what's there and use painted risers and new wooden treads.
Do not try and paint the linolium.
Basement wasls, vapor barrier , options for what i have to work with bf514921 Building & Construction 3 07-12-2012 11:26 PM
What is the correct way to redo stair treads. John/Suz Flooring 5 10-13-2011 08:11 AM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 01:13 AM
Adding Subpanel for Basement - Few Questions mindle Electrical 28 01-07-2010 08:49 AM
layout, basement redo yellow.shoes Remodeling 1 10-20-2004 08:04 AM
