Basement Shower Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 05:06 PM   #1
Angry
We have a shower in the basement. The floor base appears to have been elevated by an aproximatly wood 2 X 2. I noticed the stain appearing on the bathroom rug near the corner of the shower after a shower was taken. I peeled off the vinyl mopboard in front of the shower and noticed that this wood was wet and rotting ( this is what caused the stain on the rug). What I would like to do is somehow is to seal this wood to prevent this from happening and then reinstall the mopboard. My question is--Is there something out there that I can use as a sealeant on this wood. To remove the wood would require removing the shower
carolfleming
carolfleming is offline   Reply With Quote
Old 03-17-2011, 07:17 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What good will sealing the wood do? If it is already wet, you aren't likely to seal it now.
The bigger issue is where is the water coming from. That's the problem you should be addressing maybe.
XXX
Shower drain problem Please Help !!!! franktash Plumbing 2 02-18-2011 01:16 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Gas smell from new basement shower ThunderCAT Plumbing 3 12-14-2009 11:09 PM
Basement Shower Drain Gas Smell ThunderCAT Plumbing 10 07-30-2009 02:04 AM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
