Basement Laminate Hardwood Moister Barrier - Flooring - DIY Chatroom Home Improvement Forum
Old 05-06-2013, 05:40 PM   #1
Basement laminate hardwood moister barrier
Hello,
I am planning on installing laminate hardwood floor on top of my basement slab. I already have a moister barrier underneath the slab itself and have performed moister tests--it is dry. My question, is do I still need a moister barrier on top since I already have one under the slab?
Thanks!
bthom2 is offline   Reply With Quote
Old 05-06-2013, 07:05 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Originally Posted by bthom2 View Post
Hello,
Thanks!
Yes you always need one to put under the laminate floor its self. Some have it attached to the floor and some it comes separate but you still need one.
JetSwet is offline   Reply With Quote
Old 05-06-2013, 07:20 PM   #3
The other idea i have is to seal the concrete before I put down the foam underlayment.
Thoughts?
Old 05-06-2013, 07:38 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
Thoughts?
If you tested and got positive results then I wouldn't think its necessary as long as the laminate is rated for below grade if it is below grade. Your foam padding acts as padding and vapor barrior.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
laminate or hardwood in basement dfarago Flooring 3 02-22-2012 06:23 PM
hardwood or laminate in basement dfarago General DIY Discussions 8 02-22-2012 08:57 AM
Hardwood and Laminate Transition seanf12 Flooring 2 01-14-2010 01:34 PM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
